Old 11-07-2011, 09:58 PM   #1
clemdaddy
clemdaddy's Avatar
NV3500 or NV4500 for C-30
got a 1-ton dually with a 4-speed granny. has the big hump tunnel and all the original equipment and low-low gears. 60mph = 3200rpm
what are the pros and cons of the later five speed trans?
install difficulty? shifter location? hydraulic clutch conversion?
towing and highway driving benefits? which would you run, 3500 or 4500?
need to do this, the dually has become the daily.
thanks, clem
clemdaddy is offline   Reply With Quote
Old 11-07-2011, 10:21 PM   #2
coops714x4
coops714x4's Avatar
Re: NV3500 or NV4500 for C-30
in a 1 ton I would go with the 4500 its cast iron and heavier built than a 3500, do you want to run a hyd clutch ?? if not you can change the front bearing retainer and run a mech clutch, installation is easy depending on what year the tranny is early years use the same bell housing as your sm465. and if you have a later year tranny you can get the bellhousing from several diff places I like the adv. adpt. as far as the shifter location its about 3 to 4 inches straight back from your sm465. you will basicly have exactly what you have now BUT with a overdrive. tho first (granny) is not quite as low
the 3500 has a intergrated bell housing and you would HAVE to use a hyd. clutch and its not near as strong, hope this helps Coop
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
Old 11-08-2011, 01:52 AM   #3
Captainfab
60-66 Nut
I agree, you will want the NV4500 in a 1 ton.
Old 11-08-2011, 08:52 AM   #4
clemdaddy
clemdaddy's Avatar
thanks guys. 4500 it is...
i think i want to convert to the hyd. clutch.
do quite a bit of towing and trailer backing seems to wear out the mechanical throw-out bearing in just a couple of years. driving skills may be an issue also, lol. i buy the best american made bearings but doesn't seem to make much difference. maybe the hyd. system will be better.
will try to find a 4500 with all the brackets and the cylinder pieces included.
thanks again, clem
Old 11-08-2011, 10:49 AM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I think someone here makes a Hyd clutch adapter for our trucks......CaptnFab I think it is.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-08-2011, 09:53 PM   #6
Leadfoot Lambert
Leadfoot Lambert's Avatar
Ive got a nv3500 in my 1/2 ton with a capt fab hydraulic clutch linkage and bracket kit, it all works perfect, nice light clutch pedal. Capt fabs stuff is top notch!
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline   Reply With Quote
Old 11-09-2011, 08:53 AM   #7
clemdaddy
clemdaddy's Avatar
too true on captfab stuff... got 2 of his ps mounting kits. they're great.
will contact him for clutch kit.
thanks again guys...
Old 11-22-2011, 03:13 PM   #8
clemdaddy
clemdaddy's Avatar
here's my C-30. some have seen this pic.
i have checked cl in the area and a couple of the salvages nearby and this NV4500 may be tough to find.
is there a better year to look for that may be more available.
the NV3500 from half tons is easier to find.
anybody got a 4500 out there. need all attachments too.
thanks, clem
Old 11-22-2011, 10:28 PM   #9
rideblue00
rideblue00's Avatar
clem, you have a very nice C-30 there. I really like the dually/flatbed setup. Thought about makin my C-20 into a flat. But then i looked for bed. Not to many around here. Or cheap either.
rideblue00 is offline   Reply With Quote
Old 11-23-2011, 10:41 AM   #10
Clyde65
Clyde65's Avatar
your not too far from me, here is an ad for ya...
http://dallas.craigslist.org/ftw/pts/2656650132.html
http://dallas.craigslist.org/dal/pts/2630658048.html
http://dallas.craigslist.org/ftw/pts/2703877263.html
Also Sprindale Ark LKQ has a couple 5speeds, not sure if 3500 or 4500 but you could call them.
Clyde65
Rebuild of Clyde
support our troops!
Old 11-23-2011, 12:39 PM   #11
clemdaddy
clemdaddy's Avatar
wow clyde, thanks!
Old 11-23-2011, 12:41 PM   #12
Clyde65
Clyde65's Avatar
Oh, BTW, I love your truck, if I had a need, that is how I would set one up.
Clyde65
Rebuild of Clyde
support our troops!
