Old 11-07-2011, 11:03 PM   #1
newmaac
Interchangable parts
I am fairly new to this site. I have found it to be very helpful in finding information, as I help my son get his 69 C10 on the road.
I am curious to find-out if there is a source for information about interchanging newer parts on these great older trucks.
Currently, I am looking to find year/make/model info to swap brake assemblies to convert to disks.
I have seen websites where we can buy a kit that has drop spindles, as well as a complete brake package, but I'd like to know if there is something sitting at the dismantler's yard that bolts-up.
Same thing with the steering column; Without major fabrication, what do you look for to swap to a tilt column?
Thanks again for past and future advice.
Mike
newmaac is offline   Reply With Quote
Old 11-07-2011, 11:08 PM   #2
LowGT
LowGT's Avatar
Re: Interchangable parts
Check out the sticky/FAQ on disc conversion here http://67-72chevytrucks.com/vboard/s...d.php?t=444815 .
There are lots of options for getting parts from the junkyard. I'm putting spindles from a 72 on my 68 C10 along with 72 ball joints and tie rod ends.
65 SWB BBW - 283, TH400
LowGT is offline   Reply With Quote
Old 11-08-2011, 12:57 AM   #3
70cst
70cst's Avatar
Hey newmaac ...
and from Ohio ...
Below is a lot of good info.
http://67-72chevytrucks.com/vboard/f...splay.php?f=28
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 11-08-2011, 06:33 AM   #4
cdowns
cdowns's Avatar
71-72 C10 is a good way to swap only down side is they are 5lugs
most anything you swap in you wont b able to use the original wheels due to design of drum brake wheels from 68 wont clear disc brakes
Old 11-08-2011, 07:57 AM   #5
Going with a conversion kit is the only way to swap and have drop spindles. You can swap 71/72 parts directly and just buy drop spindles. You can swap later parts,too. You'll need to change the tie rod ends. I believe the entire a-frame assembly interchanges into the late '90s,though I can't say from experience.
