Designated A-hole!
Will 87-91 blazer tank fit?
Will it mount underneath my swb bed like the 69-72 blazer tanks?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
A guy with a truck
Re: Will 87-91 blazer tank fit?
Not without removing one or both of the rear crossmembers. They should fit quite well in a longbed though...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Designated A-hole!
You think the fuel pump assy from a 99 burb will fit the flange on that tank. I know the pump is different but the flanges look the same in my memory.
Designated A-hole!
I did some digging at the u-pull it, it would appear that the tbi fuel pump assembly is the same size as the early vortec fuel pump assembly, but the 99 fuel pump assembly is plastic and won't fit the tbi flange.
A guy with a truck
There is a Walbro replacement that will fit, but I understand trying to do it 'on the cheap' and using factory parts. Try searching around ColoradoK5 forums, or maybe LS1 truck forums. I'm sure someone else has done an LS swap into a TBI Blazer/Sub...
