Old 11-07-2011, 11:52 PM   #1
MyDad'sTruck
Stock Muncie SM465 and T221
I need to rebuild the stock T221 or swap it for a new Tcase. I continue to read good things about my transmission, and like the low gearing, so i am keeping the Muncie 4speed. About 100,000 on the muncie, we are the original owners of the truck. What t-case will bolt in easy? Thanks.
MyDad'sTruck is offline   Reply With Quote
Old 11-08-2011, 12:13 AM   #2
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Stock Muncie SM465 and T221
NP205 10 spline. Direct bolt in.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 11-08-2011, 03:01 AM   #3
JDeere550
JDeere550's Avatar
what he said^
1970 C/20 4x4, 350, sm465, np205(She tipped over... total rebuild from the frame up!)
ya gotta keep on keepin' on,
Life's a garden, dig it!
JDeere550 is offline   Reply With Quote
Old 11-08-2011, 01:54 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
When my T221 ate up a bearing I swapped in an NP205 and found I had to make a few changes so I wouldn't call it a direct swap.
Here's a thread where I talk about my swap.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-13-2011, 03:33 PM   #5
67mater
67mater's Avatar
are you sure it's an sm465? the sm420 originally came with the t221. just want you after the right info...
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 11-14-2011, 12:14 AM   #6
jbclassix
Junk Yartist
jbclassix's Avatar
I think 67-68 had the SM420. I think 69 was the first year for the SM465.
My 69 has the SM465 and the T-221.
-Jeremy
Rebuilding an NP205
Old 11-14-2011, 12:01 PM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
My 69 originally had a three on the tree manual hooked to it's T221. It would constantly bind so I swapped in an SM465 that had been mated to a T221. As jbclassix stated, the SM465 T221 combo was offered and I, too, think it occurred in 69.
Old 11-15-2011, 05:48 PM   #8
MyDad'sTruck
I am not sure where I got these T221 diagrams, but I hope they help others.
By the way, what's a "gear splitter" and what does it do?
Old 07-20-2013, 08:32 PM   #9
MyDad'sTruck
I found a T221 model N 1 TCase mated to a SM465 that was supposedly in a 3/4 ton 67 chevy. See photo. Will this transfer case bolt right in to replace my T221 model N 3 Tcase that is in my 68 1/2 ton? Tags on the cases both have 1.94 gear ratio. the only difference i see is the model 3 vs 1 I have same SM465. Apparently the 67 also had a 327 v8 as I do. Here is the one i found, but i cant load photo of mine. thanks!!![ATTACH]1134447
