Old 11-08-2011, 03:57 PM   #1
Slammed50
Cab ID question...
What, if any, are the differences from a 62 cab to a 63 cab?
Check out my build thread for my '63:
http://67-72chevytrucks.com/vboard/s...49#post4806049
Slammed50 is offline   Reply With Quote
Old 11-08-2011, 09:54 PM   #2
cb1965
cb1965's Avatar
Re: Cab ID question...
I believe the mounting points are different. 60-62 has a narrower frame
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 11-09-2011, 01:08 AM   #3
Captainfab
60-66 Nut
The front cab mount holes in the '60-'62 cabs are wider than the '63-'66 cabs.
Another way to tell is, the '60-'62's came with the dual master cylinder. One side for the brakes, and the other side for the clutch. If the master is gone, there will be 2 round holes, aprox 2" in diameter. Also, the '60-'62's had the cable operated kick panel vents with the louvers.
Old 11-09-2011, 01:52 AM   #4
cb1965
cb1965's Avatar
srry. thanks for clarifying captain
'66 chevy lwb c10
'65 chevy lwb c20
Old 11-09-2011, 12:08 PM   #5
Slammed50
Great, thanks for the info.
Old 11-09-2011, 12:17 PM   #6
oem4me
my '62 has the lever vents. '61 may have been the last year for cables.
Old 11-09-2011, 01:52 PM   #7
Bears63
...just another truck junkie..
Bears63's Avatar
I think '61 was the last year for cables as well. Also, the front mounting points are the key since in '63 the four wheel drives had a dual master cylinder as well.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 11-10-2011, 01:22 PM   #8
Slammed50
Do you guys happen to know the measurement of the width of the front mount hole centerlines for the 62 and 63?
