Old 04-18-2003, 12:11 AM   #1
PJ_STYLES
Rockers1/2"off the ground
PJ_STYLES's Avatar
Question What year/motor to use chrysler a/c pump for air ride pump?
Hi all just wondering what chrysler year, model and motor i should be getting an a/c pump out of to use for my air ride motor pump? I need details on hook up also. thanks.
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca
PJ_STYLES is offline   Reply With Quote
Old 04-18-2003, 01:09 AM   #2
JHickson6
I Love This Stuff!
JHickson6's Avatar
Check out this site for info http://www.onboardair.com/ there's a link on the left to help identify York compressors. They sell them for ourageous prices, but i picked mine up for $60US off of ebay. Mine was from a Triumph, but they've, been found in a lot of Volvos too!
Good Luck
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 04-18-2003, 01:02 PM   #3
Slammed67
Progress = 0%
Slammed67's Avatar
I recently pulled one off an '81 Mustang and it turned out to be the high output model I paid about $30 for it at the salvage yard. Haven't installed it, but I did hook a drill up to it and cranked it over and it seemed to be working. I also tested the clutch and it seems to be working also. All I need now is to make some mounting brackets.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 04-19-2003, 12:18 PM   #4
rigo
Flake Daddy
rigo's Avatar
I recently pulled a york 210 off of a early 80's volvo.....it was a remanufactured one and dang near looks new....just need to build some bracketry for it..........the yard charged $40 for it.
rigo
1968 SWB Fleet Daily Driver 350/TH400 shaved driprail,emblems,tailgate,air ride suspension
1964 Pontiac Catalina 2dr. hardtop shaved everything, air ride suspension
1998 Range Rover
1960 El Camino....in the works.....
rigo is offline   Reply With Quote
Old 05-25-2003, 10:50 PM   #5
PJ_STYLES
PJ_STYLES's Avatar
Exclamation
I got a 77 chrysler A/C pump that i had laying around here but when i went to look at it. There is oil in the pump so it doesn't wear out. (that is standard with chrysler pumps, not alot of oil) but my question is if i use this pump how to i keep the oil that is in it from slowly making it's way through my air lines and to my bags?? Oil water seperator trap? or something else??
Old 05-26-2003, 01:20 AM   #6
JHickson6
I Love This Stuff!
JHickson6's Avatar
well i'm sure there's a filter that you could get, but a little oil in the lines isn't a bad thing, plus it keeps the valves lubricated, and it won't hurt the bags! For these pumps the oil that comes out it mainly due to the angle at which it is mounted, vertical is best! Good Luck!
My Rides
