Which 6cyl is it?
how do you tell a 250 from a 230(235)?
just curious, stepdad is giving me his running 6 cyl he doesnt know which it is either... thanks WES
Wes 1965 chevy c-10 short fleet,http://www.67-72chevytrucks.com/vboa...d.php?t=474572 1999 dodge swb 3.9 DD 2002 chevy 2500 hd 6.0 4x4 (ol' ladys truck) |
Re: Which 6cyl is it?
If im not mistaken, the difference between the 230/250 is the stroke (crank). They use the same block and have the same bore. You could check the casting number on the crank. I have the same problem and i still havent found an easier way to tell the difference. But if it is a 230, i hear you can convert it to a 250.
"Where were you in '62?"
![]() Join Date: Jul 2004
Chevy Six Cylinder Casting Numbers
http://67-72chevytrucks.com/vboard/s...d.php?t=356268 Casting Number Lookup Tool Chevy Six Cylinder Casting Numbers can usually be found just above the starter on the "passenger side" of the block. http://www.adchevy.com/tools/castinglookup/ Second generation 1936–1962 Chevrolet Blue Flame six (also used in some GMC Truck models) http://en.wikipedia.org/wiki/Chevrol...ond_generation 1962–1990s Chevrolet "Third generation" six http://en.wikipedia.org/wiki/Chevrol...ird_generation Online engine resources (casting numbers, calculators, etc.) http://67-72chevytrucks.com/vboard/s...d.php?t=382583
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
distributor position is the dead giveaway , 230 , 250 292 the distributor is toward the front 216,235,261 is more towards the center .. also the belhousing pattern is different ,235 is directly on the back of the block , the 250 is wider at the rear and the same pattern as a 350 chevy ...
thanks guys, I'm going to take a look at it today, Ill post some pics and get the casting #s
Active Member
![]() Join Date: Jul 2007
For further reading... I found this site discussing a similar question.
http://www.webrodder.com/phpBB3/view...e7c0f1aa92b5e6 |
