Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 11-08-2011, 08:07 PM   #1
oldblue72c10
LIGHT' EM UP!!!!!!!!!!
oldblue72c10's Avatar
How to run 2 or 4 ohm?
I was wondering if someone could explain how to run 4 or 2 ohm on a subwoofer through a amplifier. Thanks
BONDO IS YOUR FRIEND WOULD YOU EVER USE YOUR FRIEND
1972 custom 10 longbed
current 360 building a racing 355
oldblue72c10 is offline   Reply With Quote
Old 11-08-2011, 08:23 PM   #2
tidos76
tidos76's Avatar
Re: How to run 2 or 4 ohm?
it depends in the sub/amp. is the sub dual voice coil or single. what ohm is each coil. and what ohm is the amp rated at?
tidos76 is offline   Reply With Quote
Old 11-08-2011, 09:14 PM   #3
oldblue72c10
Its a 250 watt two way jensen amp, Im probably gonna have a kicker comp 10"
Old 11-08-2011, 09:45 PM   #4
Chad215
You're not giving enough information.
Typical car audio is 4 ohm. You can wiring up in series or parallel in order to change the impedance the amp sees. Think of impedance as resistance. The less resistance, the more power that will flow from your amp. However, most budget amps will not safely or reliable crank 2 ohms without sacrificing some components. And once you let the smoke out of electrical components like resistors, it's hard to get it back in there
If all you have right now is an amp, you need to determine what your amp can handle, then purchase speakers based on that. Most subwoofers will have the same model available in either 4,6,or 8 ohm. Some will have DVC and allow you more options.
I suggest you do a little more research on your own before you start randomly hooking up amps and speakers. More than likely you'll be fine, but if you get silly and wire up a 1 ohm load to a min 4ohm amp, you'll start to have problems pretty quickly.
'64 GMC in progress
http://67-72chevytrucks.com/vboard/s...d.php?t=484861
Chad215 is offline   Reply With Quote
Old 11-08-2011, 10:07 PM   #5
tidos76
tidos76's Avatar
most kicker comp 10's are 4ohm. depending on the amp depicts how you hook up the speakers. if you can get model number of your amp and subs you are thinking it will help alot. IMO a 250w amp probably wont be enough for a kicker comp. i believe they are 600w rms......it will sound like a 6x9...
Old 11-09-2011, 12:03 AM   #6
85gmc2tone
if u had two svc 10 you could wire them down to 2 ohms if ya amp can hande it
wire em in parrallel i think. a pioneer 760 would work great
85gmc2tone is offline   Reply With Quote
Old 12-06-2011, 09:28 AM   #7
john_p
in series ohms are additive.. 2ohms+2ohms.. so if your amp has a 4 ohm output... wire two speakers in series... one wire from the amp to spk a, one with from spk a to spk b, another wire from spk b back to the amp..
if you wire in parallel. two wires from the amp to spk a, two wires from spk a to spk b.. then it gets a little harder to eng.. but it is simple with just two speakers,, two 4 ohm speakers wired in that manner would look the same as a 2 ohm speaker,,
john_p is offline   Reply With Quote
Old 12-20-2011, 03:10 PM   #8
vegas80step
vegas80step's Avatar
here is a post I took from my thread. (hope it's cool)
These links were VERY helpfull. take the time to read through them and you will have a much better understanding. hates off to WAAF for all the help...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 12-21-2011, 01:16 AM   #9
Malcolm1
Malcolm1 is offline   Reply With Quote
Old 12-21-2011, 09:33 AM   #10
WAAF
These links were VERY helpfull. take the time to read through them and you will have a much better understanding. hats off to WAAF for all the help...
don't thank me.. I just posted links.. the guys at rockford are killer..
WAAF is offline   Reply With Quote
