Old 11-08-2011, 09:51 PM   #1
71rustpile
71rustpile's Avatar
6.2L L92 questions
Hey Guys,
I picked up a 6.2L L92 engine out of a 2007 Escalade a couple weeks ago and have some questions. Sorry if these have been asked before but I'm almost brain dead from searching for specifics. I bought the engine minus the accessories but it included the AC bracket. I bought a Alt/power steering bracket on Ebay that included the Alt, power steering pump and water pump so now I'm only missing the AC compressor. So I'm nearly set on my accessory drive, just need to get an AC compressor.
First question is what transmission would be ideal to put behind this engine? I would like to keep my stock gauges if possible. I think stock it had a 6L80E but I've checked around and they're pretty spendy.
Next question is regarding wiring harness and ECM. Should I be looking for a particular harness and ECM or go aftermarket? I'm putting this in my rusty 71 shortbed so I'm assuming some things could be eliminated from the harness??
Last question (for now) is what is everyone doing for fuel tanks? I would like to keep my stock behind the seat tank if possible but not opposed to just plopping a cell in (or under) my bed.
All info will be greatly appreciated! My plan is to finish this swap and have my 71 sideways by spring!!
Dan
71rustpile is offline   Reply With Quote
Old 11-09-2011, 12:45 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 6.2L L92 questions
The 6l80e is a sweet trans but your going to pay a heavy price for it.
There are probably 2 options I would go with; I'd mostly likely go with a 4l80e. Its stout enough to handle even a souped up l92, and you can still find them on CL and wrecker yards for a decent price. There's enough out there in the way of aftermarket as well, should you decide to do a different converter etc.
You could also consider a 4l65 or 4l70, as I've heard those are much stronger than the 4l60, and becoming more available.
You'll want to get an ecm from a v8 automatic truck, it should have most of the parameters you need to plug in, and start the truck...minus the removal of VATS.
If you use a stock harness, then go with whats available, but an aftermarket piece can simplify things a lot. Mine was setup for what I wanted, with all the emissions etc already deleted. It also came with a pre wired fuse block, all I had to do was mount the block and ecm, then plug in the matching molex plugs. Engine wiring was probably a 25 minute job tops, including switching over my injector plugs to EV6 instead of Multec II (more on that if your interested).
Get rid of the in cab tank. It takes up legroom, its debateably dangerous, and it would suck to have an electric pump in the cab as well...all that humming.
There are some companies that make FI ready fuel cells, with sumps for external pumps, or some even setup with internal sending unit/ in tank pump setups. Even going with a cheap sumped AL fuel cell, and running an external pump can be done even with a budget in mind.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-10-2011, 02:15 AM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
make sure you get the correct year transmission... the newer the better... there are older 4L80e and 4L60e that came behind the no LSx Vortec motors... they changed around 1999/2000 depending on the truck....
Sames goes for the harness. the 07 is a Gen IV so the harness need to be for that motor. Something to do with sensor types, reluctor ring, etc....
Rich
1972 K5 Blazer CST Click HERE
Old 11-10-2011, 02:57 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
the gen IV use a different # of teeth on the reluctor ring. They are also variable valve motors so the cams are different.
I'm pretty sure the year of the trans doesn't matter if your planning a rebuild. Stock for stock, the newer stuff is better, you are correct.
Also, make sure you find a trans with the correct tail shaft. Getting a 4wd trans will cause headaches for a 2wd swap.
Old 11-10-2011, 03:41 PM   #5
c10seconds
c10seconds's Avatar
Are you going to use car accessories and intake? Do you plan on removing the VVT?
c10seconds is offline   Reply With Quote
Old 11-11-2011, 12:27 AM   #6
mcbassin
Still Learning
mcbassin's Avatar
The 6L80 is bad A but I bet they cost a truckload of cash. I would think a well built 4L60e or stock 4l70 or a 4l80 would do what you need depending on what mods you make.
You can buy some of your missing parts on LS1 site. They have lots of sellers in the classified section. I just picked up a dbw pedal for my setup over there pretty cheap.
I picked up a Blazer tank from Kennys trucks pretty cheap. I am planning on using a Walbro external pump. You can spend as little or as much as you want for a tank/pump setup.
mcbassin is offline   Reply With Quote
Old 11-11-2011, 10:30 AM   #7
71rustpile
71rustpile's Avatar
I plan on using the truck accessories and keeping the VVT. Planning on getting a comp cams VVT cam, read that it will bump it up 69HP. Thanks for all the info guys, keep it coming!
Old 01-12-2012, 09:53 PM   #8
71rustpile
71rustpile's Avatar
Thanks again for all the great info! Now I've decided the 4L80E will be the best route to go bang for buck. My question is can the 4L80E be tuned to work with my VVT L92? Any help with this would be great so I don't waste a wad of cash on something that won't work. Anyone familiar with the tuner programs that could check to see if its possible to tune that combo?
Old 01-12-2012, 10:32 PM   #9
Mr. 250r
Mr. 250r's Avatar
Well in terms of 4l80e there are a good amount many differences mine being 91 has neutral safety switch on the steering column now after that I think there is about 3 more wiring changes and also a 4l85e as well but the second years I think had the 4 wire neutral safety switch on tranny then the other plugins which can be swapped into the older years like mine, after that the neutral safety switch went to I think a 6 wire and then on to even more ill take a pic of my 05 wire tomorrow but anyways just a little info hope its not too confusing but aside from some internal changes, neutral safety switch move and more wires all good :-p
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 01-12-2012, 11:05 PM   #10
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Defiantly talk to a tuner. I have no idea about the VVT, but the 6.2 can be made to work with a 4l80e. When they went to the GEN IV 58x engines, they also went to separate controllers- Engine control module (ECM) and trans (TCM). The 6L80E has the TCM in the pan, but the 4l80e is separate and mounted next to the ECM. PM member Shon, he tunes and may be able to help.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-12-2012, 11:42 PM   #11
mooseknuckles
mooseknuckles's Avatar
6l80e's are the six speed auto's?
mooseknuckles is offline   Reply With Quote
Old 01-13-2012, 12:44 AM   #12
usmcchevy
usmcchevy's Avatar
Yep, and the 6L90E's
Build thread
LSx Swap FAQ index
Old 01-13-2012, 12:35 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
gm is gonna run out of numbers for these... some day, that 10L95e will come out lol
Old 01-13-2012, 01:04 PM   #14
mooseknuckles
the 6 speed auto would be nice...but I'm sure the price would be ridiculous..as would finding a used one...
Old 01-14-2012, 05:46 PM   #15
Mr. 250r
Mr. 250r's Avatar
a quick search of them rebuilt or some problem ranged from 1500-2200 for the 2010-2011 1500 and 2500s
2003 1500 Silverado
