Old 04-18-2003, 01:04 AM   #1
stateamind
And you call that a what?
stateamind's Avatar
Question A/C compressor question
Anybody know if it's possible to run a new style a/c compressor, say from a 92 chevy on my 72 c-10? Reason I ask is I am thinking of running the front brackets from a 92, since I have them and the old compressor wasn't there when I bought the 72. I like the small size of the compressor on the 92 model and would like to run a serp. belt too. Anybody done this? If so, maybe a pic or two?
Thanks all
stateamind is offline   Reply With Quote
Old 04-18-2003, 04:07 AM   #2
73stepside
73stepside's Avatar
i want to do this set up too. i doesn't look to hard. you will have to change the water pump to the new long style with reverse rotation and get new pulleys. the old ones from the donor teuck should work just fine. it's also a good time to upgrade to a high output alternator, which should be with the donor. i think the a/c compressor will work with the old system but i am not sure. i am going to pull the whole a/c system from a donor truck, just so i have everything that i may need. hope this helps. i would like to know more info on the a/c comp too.
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 04-18-2003, 04:24 AM   #3
krue
Designated A-hole!
krue's Avatar
I am gonna try taking the compressor and condensor out of a 92 S-10. Hopefully I can make it work!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-18-2003, 08:30 AM   #4
Class of 69
Class of 69's Avatar
I believe Classic Ind. makes a conversion kit to use the newer clutch cycling compressors. You have to remove the filter dryer, POA valve, and reroute some of the freon hoses. Add an accumulator and orifice valve. Wire in a pressure switch to regulate the compressor clutch, and waalaa. You have a clutch cycling system.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 04-18-2003, 08:58 AM   #5
krue
Designated A-hole!
krue's Avatar
Djoesn't sound too hard! (FAmous last words!!!!)
www.daveramsey.com
Old 04-18-2003, 09:33 AM   #6
Class of 69
I hear ya there, krue. I think the serpentine belt conversion will be the hard part, getting all the right pulleys to line up. I'm assuming you guy's would be converting to R134a freon too. The kit I mentioned from Classic comes with all the parts to change over...something like $350.00 for cost, so it isn't cheap.. I think a guy could find all the pieces in a bone yard for much less, or a donor truck would be ideal.
Old 04-18-2003, 12:44 PM   #7
Blue68
Blue68's Avatar
Something like this perhaps? It looks a little different now but this is all from a '98 Z-71. The compressor isn't hooked up yet but the hoses are gone, cut them off the hose block and will have new ones of the correct size welded (brazed, heli-arch) to the existing block and routed correctly.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
