Ignition Switch Removal
Hey guys, Im trying to remove the ignition switch from my dash bezel. It is impossible to remove it by unscrewing the retainer nut since the keyed area is larger than the nut. there are two holes on this particular ignition so i dont know if it is stock or not. Ive tried the paper clip trick to no avail. any ideas?
86 K20 6" lift 66 C10 LS2 T56 1947 Ford Rat Rod Softail Deluxe Softail Chopper |
![]() Join Date: Oct 2009
Re: Ignition Switch Removal
there is a specialized tool to remove it - has two prongs that fit the holes, then twist. Now, if you want to try the approach I tried, I took two scratch awls, inserted in the holes, and gave em a big simo whannng... (I'm not kidding, but this was many years ago) It came off but the gouge I put in my dash made me want to cry. I now own the tool....
Take a small flathead screwdriver holding it at a angle to (push) or turn and tap lightly with a small hammer to turn it,that should work.
Do the paperclip trick while turning the ignition switch.... may have to play with it but should come right out.
![]() Join Date: Nov 2008
A pair of needle nose pliers , work wonders ....
#6 | |
Senior Car Nut
![]() Join Date: Jan 2008
2 holes, maybe not stock?
Larry Last edited by fleetsidelarry; 11-09-2011 at 09:22 AM. |
Guess what! I got it out!
Drilled out the two holes with a 1/8 bit, then used a pic to push down on the small brass pin. Thanks for all of your help!
