11-09-2011, 12:43 AM | #1 |
Intake casting number.
Hey guys,
Do anyone here have any good links for the casting numbers for a factory 350 that are for our trucks, I am currently trying to find the correct intake manifold for my 1971 cheyenne? Derrick |
11-09-2011, 01:41 AM | #2 |
Hand Crafted C-10
Re: Intake casting number.
I would poke around on the NastyZ28site.
A few tips from someone that's been there... Be sure when shopping for a cast iron intake to take the tin plate (heat shield) off the bottom, chip away the carbon, clean and check for cracks. If it looks good, DO go as far as a magnaflux to be sure. Our local shop charges $15-$25 (depending if they have to sandblast). It will save a lot of time and $ if it proves hiddenly cracked. I want through this years ago and had to reject many, many before finding the correct & good intake. In my case it was a '68 327 so it may be easier with a later model 350. Good Luck! |
11-09-2011, 04:35 AM | #3 |
Try this link: http://outintheshop.com/faq/casting/castings2.html
This should have the information that you need plus anything else you might need for later. I just have it bookmarked on my computer so it's easier to find when I need it. Good luck! Keith |
11-09-2011, 12:04 PM | #4 |
Grandpa in the rustmobile...
i gotta intake from a 71 gmc sierra with 350 dont know if its cracked i went with edelbrock aluminum msg me for the numbers if your interested lol problem is its probably heavy for shipping.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
11-09-2011, 11:21 PM | #5 |
