Old 11-09-2011, 04:11 AM   #1
FLEET72
FLEET72's Avatar
Why do they do it?
On my 72, some previous owner, there have been at least 2, cut off the bump stops on the lower control arms. The truck wasn't lowered or anything but...?
So my wife wanted disk brakes on her 69 GMC. At picknpull we find a 72 donor. I get both the spindles and lower control arms. when I was seperating the various parts I find:
After carefully grinding out the welds with a die grinder I press out the ball joints. They were still quite snug in their bores but someone had tacked them in...WHY?
I just don't get it!
OK, rant over.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 11-09-2011, 06:12 AM   #2
cdowns
cdowns's Avatar
Re: Why do they do it?
tack welding ower ball joints is and was a very common practice by some mechanics. especially on trucks that were commonly used as work vehicles and rough usage situations
Old 11-09-2011, 07:52 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Years ago I took my 69 Chevelle for an inspection and they noticed the lower ball joint loose in the control arm. Said it was common so they tack welded it back in place.
I've never had any other cars/trucks with that problem since though.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 11-09-2011, 11:49 AM   #4
big_al_71
big_al_71's Avatar
Those balljoints are pressed in and as already mentioned there hvae been cases where the ball joint has popped out specially in the lower control arm so people did this to ensure that they would not pop off.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-09-2011, 04:55 PM   #5
FLEET72
FLEET72's Avatar
OK, so that explains the ball joints. But why cut off the bump stops if not lowering the truck?
Oscar
'95 Jimmy 4X4
Old 11-09-2011, 08:47 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you overload it on a regular basis, this would make it ride a tic better when loaded like that
Old 11-09-2011, 10:03 PM   #7
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
When I had the front end rebuilt on my 75 Chevelle, the control arm shaft nuts were welded on. I guess its something people do.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 11-10-2011, 09:52 AM   #8
yuccales
yuccales's Avatar
My 75 GMC Sprint had the same thing. Never knew why.
yuccales is offline   Reply With Quote
Old 11-10-2011, 02:02 PM   #9
FLEET72
FLEET72's Avatar
Something missing.
Oscar
'95 Jimmy 4X4
