11-09-2011, 11:41 AM | #1 |
Broken shock tower
Hey everyone,
I have a broken top shock tower on the rear passenger side of my 82 K30 and have called local junkyards but no one has a 1 ton, only 1/2 or 3/4 ton trucks. I've looked around on the Internet but can't find anyone that sells them, my guess since the thing is riveted on the frame. My question is: will the 1/2 or 3/4 ton trucks shock towers fit the 1 ton or is it strickly 1 ton only? I haven't had the time to go to a junkyard to compare the shock towers so I'm hoping someone here can help. Any and all advice will be greatly appreciated. Thanks in advance. Eric
"Fork: an instrument used chiefly for putting dead animals into the mouth." - Ambrose Bierce 1982 Chevy K30 |
11-09-2011, 11:27 PM | #2 |
Robert Olson Transport
Re: Broken shock tower
AFAIK the one ton is an animal unto itself.. id check the parts board sometimes people part one tons try member teeitup hes a vendor
11-10-2011, 08:14 PM | #3 |
There are no shock towers on the 1/2 ton. The upper shock mount just bolts to the frame with a shock bolt.
Just throwing this out for something to think about, see other attachment, which shows the upper mount for a 1999+ ck. Look similar? If you goto Monroe, you can see if the upper shock eye is the same between the 1 ton and the 99, if it is, graft on an upper mount from a later truck. Alex. |
11-10-2011, 08:32 PM | #4 |
As 'old rusty c10' stated, the C/K30 utilizes an upper bracket specific to the C30 chassis. They mount inboard of the frame-rail vs. the upper stud that attaches to the outside of the frame on the smaller trucks.
You could look for someone parting a C30 out or build a new mount from steel.
11-11-2011, 12:00 AM | #5 |
when i bought monroe shocks they came with the shocks
(sensatrack)
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
11-11-2011, 04:58 PM | #6 |
Does it look anything like this one? Mine cracked where the shock bolt goes in, and I just welded on a couple thick washers. It's been about a year and haven't had any problems with it. This is on my C20 3/4 ton suburban.
11-14-2011, 12:09 AM | #7 |
Thanks for all the responses.
Upon closer inspection of the shock tower today, I found that the shock bolt that is welded to the tower was broken off and not the shock tower itself. I felt relieved to see that, so I think I will fabricate and install a shock bolt for the thing and call it a day. Thanks for all your advice. Eric
11-14-2011, 03:46 AM | #8 |
Glad you can work this out man.
FYI, GM is also a decent source. My Dad's 94 K1500 rear shock mounts rotted out, but he was able to buy new pieces from GM. That may also be possible for the C/K30 squares |
