Old 04-18-2003, 02:34 AM   #1
jasonrog
jasonrog's Avatar
PS Box
I need to replace the power steering box on my 71 chevy LWB. Are there any boxes more desirable than others?
jasonrog is offline   Reply With Quote
Old 04-18-2003, 02:38 AM   #2
JHickson6
I Love This Stuff!
JHickson6's Avatar
Well they say that the 73 up have a quicker ratio and suposidly bolt right up, but i'm not sure and i'd like to know how it goes!
Jared
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 04-18-2003, 02:42 AM   #3
jasonrog
jasonrog's Avatar
My present one is off of an 80's truck. It started to leak so I want to replace it.
Old 04-18-2003, 02:43 AM   #4
JHickson6
I Love This Stuff!
JHickson6's Avatar
Did it bolt right up? or did you have washers and shims in there? Wondering cuz my 67 frame has indentations, does your frame? Thanks Man
My Rides
Old 04-18-2003, 03:10 AM   #5
lpaine
lpaine's Avatar
I once installed a power box off a late 70's truck on to my 72 Jimmy that I used to have, it was a simple, straight-forward bolt on. I believe in the eighties gm started using a "metric" power steering box, you will want to avoid those. The bolt pattern should be the same-4 bolts onto the frame-you should'nt have any problems bolting a newer box on. Check the wrecking yards, tons of 'em are around still.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 04-18-2003, 09:01 AM   #6
casey
casey's Avatar
Ipaine Whats the problem with the metric ones?
casey is offline   Reply With Quote
Old 04-18-2003, 10:03 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Installing hoses would be a PITA. You'd need a hose with SAE fittings on one end,a dn metric on the other...or some sort of stupid adapter or something.
Old 04-18-2003, 11:57 AM   #8
jasonrog
jasonrog's Avatar
It bolted reight on. No spacers. I think I have the indents too.
Old 04-18-2003, 12:00 PM   #9
Randy70C-10
Randy70C-10's Avatar
Don't know how your parts stores are up in Canada, but you can still get new PS boxes here for around $125
Randy70C-10 is offline   Reply With Quote
Old 04-18-2003, 12:54 PM   #10
gr8scott51
gr8scott51's Avatar
I just bought a remanufactured box and pump with new hoses and rag joint for $250 on ebay.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
