Old 11-10-2011, 11:31 AM   #1
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Power steering conversion questions...
OK, simple but i tend to overthink things sometimes. My 68 swb, project Cheap Bastard, is a manual steering truck. Looking to buy a donor truck with power steering. Can I just switch gearboxes and pitman arms and of course mount the pump and be in business?? Thanks.
specialtyretail is offline   Reply With Quote
Old 11-10-2011, 12:51 PM   #2
Sammy
Re: Power steering conversion questions...
68/72 donor ..Yes..hardest part you may run into will be the pulley alignment..But if your donor has a long / short water pump like yours it will be an easy conversion. It is the mixing of pulleys that create the issues. Good Luck!
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 11-10-2011, 01:24 PM   #3
specialtyretail
Hey Sammy. Thanks for the input. That is what I thought. The brackets are for small block and my truck is big block but that is an easy fix. Thanks again, Fred.
