misshape grape
let's talk steering columns.
I have a 35" tilt column that was put in my truck by the previous to previous owner. I know(assume) it's not factory (83' Scottsdale) as it has cruise and wipers on the stalk.
My truck also has a dash wiper switch. Is there a shorter tilt column that will swap with relative ease? At a junkyard we found tons out of all 80's GM vehicles, but nothing quite will fit perfect. I believe mine is out of a suburban. Just want to have a little more room. thanks!
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did.. |
Re: let's talk steering columns.
X2 great question pat! was going to start researching this very topic today
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
misshape grape
My brother and I tried 80's s10 blazer, 80's cadillac sedan, they were shorter but not a direct swap
misshape grape
My 83. Now with 3 inches less of steering column.
The One And Only !!!
So what did you do Pat, Find the seat slider lever ?
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
misshape grape
haha! My brother shortened a c10 column. Used a s15 jimmy shaft and had to do some welding for brackets. All in all, it feels better!
hey pat, could i get some details on the steps took to do that mod?
misshape grape
I will get have to get with my brother and get more detail. But I do know the shaft and tilt mechanism is out of a s10/s15 blazer/jimmy, nuts for the mounting bracket were welded on 3 inches higher, and the ignition switch had to be moved.
I think the external housing of the column was collapsed, and you could probably use a c10 shaft as long as you collapse it. We used the tilt top out of the blazer as we didn't want to tear my good tilt column apart so I have a spare. We might experiment with a cadillac tilt/relescope column. But the telescope feature kind of takes away from the column shortening anyways haha Posted via Mobile Device
78K & 79C Jimmys
nice work I'd like to see how it was done too pls
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
I would love to have a steering column that short, but no idea how to accomplish. Would a custom built one work from Flamming River or someone else? I'm thinking tax return money might not make it so bad.
