Old 11-10-2011, 07:37 PM   #1
8848stro
8848stro
fuel tank
Has anybody relocated an aux tank between the frame rails?If so how did you hook-up the filler neck,on a 71 lwb. the tank I used is the 16 gallon from LMC.
8848stro is offline   Reply With Quote
Old 11-10-2011, 09:35 PM   #2
Ironhorse
Ironhorse's Avatar
Re: fuel tank
Not sure about the " aux " tank portion but I removed my in cab tank from behind the seat and installed a poly tank from GMC Paul's. Did it several years ago and glad I did. Gives me some more storage room behind the seat and I was able to use the corner speaker mounts that bigblock73, (board member and nice guy all around) fabed. I have them installed now but not hooked up. If you would like I could take some pics in a day or two of my rear tank set-up and give a brief how-to, at least the way I did it anyway. Took very little welding skills of which I have none or the welder either.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
