Old 11-10-2011, 08:00 PM   #1
cochino12
It followed me home?
cochino12's Avatar
Which of these bags to use for my air over leaf?
Just got my AOL kit from ridetech and they sent me double convoluted bags (f6957) and I thought I was getting a tapered sleeve. I have a pair of ride rite 9000 which dont have quite as much load rating but according to the specs I should get a lot more lift if I use the tapered bag.
The convoluted bag lists
3" compressed 4.5-5.5" ride height, max 7"
sleeve
4.5" compressed ride 8-9.5" max 13"
I dont use the truck to tow anything so I'm not real worried about the load rating. Am I missing something or am I ok to use the firestone 9000
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 11-12-2011, 12:10 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Which of these bags to use for my air over leaf?
I would use the sleeve bag.
Keith
Convert to disc brakes.
Old 11-12-2011, 12:36 AM   #3
bagged74
its just $$$$$
bagged74's Avatar
I have sleeves on mine
bagged74 is offline   Reply With Quote
Old 11-12-2011, 07:55 AM   #4
cochino12
cochino12's Avatar
Thanks guys, I ended up with the sleeve bag a.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 11-12-2011, 10:29 AM   #5
SCOTI
SCOTI's Avatar
They supply the smaller dbl convoluted bag on the HD applications for towing.
The C10's use the sleeve type bag so they would work too. I used the same small dbl convoluted bag on my 74 when I did my 'driveway' AOL set-up on my old 74. I did that bag specifically because of the spacial requirements (I placed the bag directly on top of the original leaf spring pad). W/no load, I kept minimal air psi in them & then just air'd them up once I connected the trailer. Worked great & you wouldn't know they were back there when unloaded.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
