Help!!!!!
My clutch went out in me 72 c20 350 4 spd i replaced the clutch pressure plate and throwout bearin but i still have no pedal, upon further investigating i found the pivot rod from th frame to the block is cracked can this be welded back even if its only temporary?
Posted via Mobile Device |
Re: Help!!!!!
i would say so as long as you can get a good weld on it where it cracked it should be good as new cant end up worse then mine that the PO notched out to clear the headers
![]() oh and just a heads watch for the grease inside to catch fire when your welding on it |
