11-11-2011, 12:28 AM | #1 |
1991 CCSWB: LQ4/4L80E Combo????
I am doing a 1991 1 ton CCSWB/SRW Project. I really want to do Duramax/Allison combo but have my hands full just doing a complete frame off resto. So for the time being I am thinking of going with a lq4/4l80e combo and saving the duramax for the future. I really want to have this on the road by summer 2012.
My question is, has anyone done or know of this combo in a CC and how did it work out for them? ie power/ towing etc? Thanks Chuck |
11-11-2011, 04:34 AM | #2 |
Re: 1991 CCSWB: LQ4/4L80E Combo????
Mine's still in progress, so really can't say how it'll drive or tow... I used an LY6 engine package from Mast Motorsports which is hotter than stock so it'll probably do great. I'm also using a NV4500 rather than an automatic...
The LQ4's are terrific motors though & as long as you aren't trying to tow a bull dozer or anything you should be pretty good. Put some pics up of the truck!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
11-11-2011, 08:35 AM | #3 |
Formerly- 1972SuperCheyenne
My 86 had a LQ4/4l80e, I loved it. Tons of power. Check out the engine section of this forum, theres a LS swap sub section with overloads of info.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
11-11-2011, 11:25 AM | #4 |
The LQ4/4l80e combo's have moved many Suburbans around w/o issue. The weight would be very similar or more vs. a CCSB conversion. The one's I've ridden in had power to spare even pulling a open car trailer.
Not as much grunt or efficiency as the diesel option.
11-11-2011, 01:16 PM | #5 |
Thanks guys, I figured it would do a decent job. By the way this is going to be 2wd if you didint know yet, Probably 4:10 gear ratio.
