![]() Join Date: Nov 2010
Door Jamb Switch help
I bought a set of door jamb switches because mine were falling apart and my dome light wasnt working right. The wires were ate up so that leads me to my question. Where to I wire the door jamb switches to? there wasnt enough left for me to determine where they go.
1961 crewcab
Re: Door Jamb Switch help
as far as I know the 60-66 dome light was only controlled by the light switch.
never in the door jamb that said, you should be able to splice them into the fuse box, use the cigarette lighter tab, this always has power, ignition , or not, the dome light is the oarnge and white wire
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Senior Enthusiast
I wired mine up using the details from this link. You’ll need the exact switch specified – Wells part number SW98 which I found at a local Auto Zone store. No other local parts house carried this exact switch, and all of the cross reference part numbers were too short.
http://www.persh.org/Pickup/DomeLight.htm |
1961 crewcab
awesome tech markeb!
