Old 11-11-2011, 11:40 AM   #1
jeremy zander
jeremy zander's Avatar
Big block I.D.
Stamped on the block 1DF506526...Big block pulled from 70 c20
WTB 1972 CHEVY 3/4 4X4
1971 chevy c30 4x4 NAPCO (project)
1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers
1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete
2006 chevy LBZ crew cab duramax,4 inch,beadlocks
2015 chevy tahoe Z71 my fifth one,love em
2016 chevy 2500HD Z71 LTZ duramax midnite
2018 chevy suburban Z71 midnite
jeremy zander is offline   Reply With Quote
Old 11-11-2011, 12:03 PM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Big block I.D.
Big Block ID is usually found on a little smooth pad on the PS cylinder head or top of the timing chain cover..heres mine. T= Tonawanda 07= Month 11= Day TRR= Engine Code
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 11-11-2011, 02:41 PM   #3
jeremy zander
Re: Big block I.D.
I want to find out if this is a 402 or 454 and what the value of it is...thanks,Jeremy
Old 11-11-2011, 03:12 PM   #4
eightbanger
454 MAKES IT ROAR
Re: Big block I.D.
Jeremy, if you can get the last three letters in one of the places I described like mine, they're called the "Engine Suffix Code" that will tell you what you have.
TRR = 1979 Truck 454
I don't think that # is the one to tell you what engine you have.....
Here is the list of casting #'s for Big Blocks.
http://www.ajgeneral.com/bbc_block_casting_numbers/
Nigel.
No more pain.
Old 11-11-2011, 03:30 PM   #5
jeremy zander
Re: Big block I.D.
OK ..thanks for the link..I will check the block again...the number I gave was stamped below the head on pass side on the block..mechanic wants to give me $500 for it..just want it to be fair deal for both...I ran the motor 10 years,used a quart of oil once a month..moderate driving...
