11-11-2011, 01:04 PM | #1 |
19 mpg
I filled up at a station on the freeway. Then drove 35 miles. I then filled up again. I used 1.83 gal. of gas. I figured I was getting 19 MPG. The truck has a 305 engine with an overdrive trans.
11-11-2011, 01:15 PM | #2 |
Re: 19 mpg
11-11-2011, 02:55 PM | #3 |
Re: 19 mpg
my bone stock 84 has a th350 with 3.08 gear and i was getting 18 mpg going to crusin the coast this year. i still have the stock plug wires too!
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
11-11-2011, 03:12 PM | #4 |
Re: 19 mpg
11-11-2011, 03:39 PM | #5 |
Re: 19 mpg
19 is really good. I got about 16mpg with my 87 GMC (305/700R4) Longbed 1/2 ton.
I would however suggest checking it over a couple tanks. You could have just had a tailwind on that 35 mile trip....
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
11-11-2011, 05:54 PM | #6 |
Re: 19 mpg
x2. One trip, one way, is not enough data to be exact. It could still be very close....
11-11-2011, 07:53 PM | #7 |
Re: 19 mpg
Yeah on a 35 mile trip you can't really get the exact mpg...I'd do a 100 mile trip just for giggles and figure it out that way.
Still *****in' mpgs for a brick rolling down the road. I'm stoked when I see 14 on the freeway and maybe 11 on the street hehe. But then again I have a sticker on my truck which reads "Fu*k Hybrids" hahaha. Posted via Mobile Device |
11-11-2011, 08:09 PM | #8 |
Re: 19 mpg
yeah I was getting 14.5 before. Then I changed the spark plugs and got 18 on the next trip
11-11-2011, 10:23 PM | #9 | |
Re: 19 mpg
11-12-2011, 08:32 AM | #10 |
Resident of Here
Re: 19 mpg
ID be glad to see my 88 do more than 12. At least its constant, towing, flooring it, coasting it, always 12mpg.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
11-13-2011, 10:43 AM | #11 |
Re: 19 mpg
GRS
Do you know what rear axle ratio you have? My plans are a 700r4 behind the 250 I6, with 342 gears and see how tt turns out As a side note: I've driven my dakota for too many miles. I've noted that the trans converter goes into lock-up mode at 55, any travel at less than that the fuel mileage goes down the Sh*ter. It seems to have a higher stall than necessary so I'm sure it's not helping. |
11-13-2011, 10:47 AM | #12 | |
Re: 19 mpg
11-13-2011, 01:02 PM | #13 |
Re: 19 mpg
The ratio should be marked on the build sheet in the glovebox
11-13-2011, 02:23 PM | #14 |
Re: 19 mpg
11-14-2011, 11:13 AM | #15 |
Re: 19 mpg
If I remember correctly my 82 and 87 did not, they just has the code for Standard Ratio.... mine were 3.07 or 3.08 whichever GM uses.
