Old 11-11-2011, 07:33 PM   #1
83 Silverado
83 Silverado's Avatar
Tow Haul Mode
I was looking a little finding for Info on make the tow haul work with my conversion, I had seen it posted before but it's not coming up in my search. Thank
83 Silverado is offline   Reply With Quote
Old 11-11-2011, 10:51 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Tow Haul Mode
For the 03-07 green/blue pcm you hook a momentary switch between J1-pin 71 and ground. Probably the same with the 99-02 pcm, no idea for the other pcm's.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 11-16-2011, 11:25 PM   #3
bryankichler
bryankichler's Avatar
Re: Tow Haul Mode
mine is a 2000 pcm using lt1swap it said pin 71 on blue pcm connector have not verified its working yet havn't fired mine up yet.
bryankichler is offline   Reply With Quote
Old 11-17-2011, 11:38 PM   #4
feller
feller's Avatar
Re: Tow Haul Mode
this just got me thinkin. can a guy make the paddle shift work in an old truck as well??? i am not building one yet just curious and the pins and wires mean nothing to me at this point just thought it might be a cool gadget to add while making the conveition
feller is offline   Reply With Quote
Old 11-18-2011, 12:23 AM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: Tow Haul Mode
yep, pin 71, set the option in HP tuners or other tuning program from bus to the other option... don thave hp tuners loaded on this computer to tell you exactly. search on HPtuners.com, ive got a post there. seach button it. I have it running on my truck for a few years.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 11-18-2011, 04:27 AM   #6
CamaroChris
Re: Tow Haul Mode
What we need to figure out is how to make a indicater lightly come on when the tow haul is on without a second switch.
I LIKE TRUCKS
1986 GMC Suburban Build Build link
1982 Chevy SWB 2wd Scottsdale, Build Link Sold
1987 Jimmy Build, Project Cheap A$$ Build Link
CamaroChris is offline   Reply With Quote
Old 11-18-2011, 11:03 AM   #7
feller
feller's Avatar
Re: Tow Haul Mode
chris could you not use an led lighted button to control it all??
Old 11-27-2011, 01:29 PM   #8
Hart_Rod
Hart_Rod's Avatar
Re: Tow Haul Mode
Good info. USMC do u have it connected on yours? If so, how is it working?
Hart_Rod is offline   Reply With Quote
Old 11-27-2011, 10:17 PM   #9
usmcchevy
usmcchevy's Avatar
Re: Tow Haul Mode
Yes I do, works great. I have the tune set up as haul butt mode, Higher shift points.
Build thread
LSx Swap FAQ index
