Old 11-11-2011, 08:18 PM   #1
6 Door King
New to me 85 Sub "Project Clusterfunk"
I found myself a 350 powered rig to replace my required 4x4 vehicle after selling my Jeep. I was fortunate enough to find one with a GM rebuilt 350, recently rebuilt trans and a terrible camo paint job for 600 bucks. Drove it home and discovered the radiator had a pin hole, the air shocks don't hold air, the front springs are beyond flat and have three inch blocks in place to compensate, and the carb is missing the choke and vacuum pot. Not complaining, I knew most of this, and for the price it is worth the trouble. Was an old volunteer fire truck, so it was red at one point, and is laced with tons of now useless wiring. I have decided to chop the rear off the top and close it in using the roll down window from the tailgate and possibly bob the rear end after working out how to replace or move the gas tank. Also considering using a Blazer top to enclose the new rear section. Does anybody know the dimensions for the top from a 73-91 Blazer/Jimmy?
1954 3100 Nova Subframe, Pontiac Posi, roller for now1967 C-10 SWB 350/350/Posi. Soon to be Crew Cab!
1978 Crew Cab Dually roller
1982 C-30 Rollback, 454, 4 speed
2004 K1500 Suburban Z71 5.3 Kid Mover
6 Door King is offline   Reply With Quote
Old 11-12-2011, 05:33 PM   #2
6 Door King
Re: New to me 85 Sub "Project Clusterfunk"
The first day of hacking has yielded a naked back half on my Sub. Tracked down a Blazer top and tailgate from a 76 and now I just have to figure out how to get it home (sub is not registered and its my only vehicle big enough to carry it). Here's what i got so far...
Old 11-12-2011, 10:20 PM   #3
Psycho71
Psycho71's Avatar
Looking forward to seeing how this comes out. Ought to be cool!
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 11-14-2011, 12:40 AM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Nice score not at bad deal at all from the looks of it. Different direction with taking the top off but that's cool cant wait to see some pictures of it when you get it all done.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-25-2011, 03:00 PM   #5
6 Door King
Been a couple weeks since I have had time to mess with the truck, finally got back on it and made a bit of progress. As I am sure most of you guys know, the Suburban has a raised section in the rear roof, and standard cab pickups don't. So, to solve this, I removed the body line on the back of the donor cab panel and dove tailed the Sub roof to meet it. Actually looks ok, not factory, but decent. After destroying the factory tailgate in an effort to make a rear cab panel with functioning roll down window, I decided to scrap the plan and build it with new panels and use the donor cab rear section. The benefit of doing it this way is that now I can remove my lower filler panel and slide in full length lumber or bigger stuff. Sort of works out like an Avalanche. Also still have full use of my flip down rear seats to extend the "bed" area. Now all I have to do is sort out what kind of tailgate I want, I have an old pickup gate, and a couple ideas on how to mod it. I am also considering building a tube type gate with expanded metal filler panels. Planning to tube out the edges of the bed, and build some sort of rack system on the rear. The open area on either side of the filler panel will eventually become tool storage areas, and possibly speaker mounting locations. The front of both wheel tubs were rotten, and it is wasted space with the new configuration, so I will reuse the space for something more effective...
Old 11-25-2011, 04:57 PM   #6
joe231
joe231's Avatar
Nice!!
Can you post an overall pic with the new back panel in?
CHEVY ONLY
Old 11-25-2011, 06:01 PM   #7
6 Door King
Ask and you shall receive...
Best I can do for the moment, too many other vehicles around it to get any better shots. If there is a certain angle you want, let me know.
Old 11-25-2011, 06:58 PM   #8
joe231
joe231's Avatar
Right on!
That's good enough!!
Thanks!
CHEVY ONLY
Old 11-25-2011, 10:34 PM   #9
justpball
justpball's Avatar
Nice work bud!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 11-26-2011, 09:31 AM   #10
6 Door King
Thanks for the compliments and encouragement. Still got a ways to go, but it's nice to have a pat on the back.
Old 11-26-2011, 09:59 PM   #11
68Timber
I know the pieces fit
68Timber's Avatar
Very nice start! So what are they calling these conversions? Avalburbs? Suburbalanche? Whatever, I like your approach.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-27-2011, 12:06 AM   #12
6 Door King
I call it Redneckery! Some evils should remained unnamed.
Old 11-27-2011, 02:29 AM   #13
Devillusion
Devillusion's Avatar
Very nice, had the same idea a while back myself with putting a power gate etc there. I like what you have done though.....with the planned bobbed rear it will make things look better as well. That section behind the wheels usually looks awkward IMO when the top is removed....can't wait to see some more progress.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 11-27-2011, 03:45 AM   #14
Pop's C-10
Pop's C-10's Avatar
nice work..when you bob tha back it will all come together
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 11-27-2011, 09:59 AM   #15
6 Door King
Anyone have any suggestions of what to do with the gas tank if I bob it? I have a saddle tank from a pickup, but only one, also have a wrangler tank I was going to use on my 67 project, as well as a 67-69 Camaro tank. I even considered dual tanks using two 67 C-10 tanks along each bedside but I have not come up with a decent way to secure them or weather proof them. Thanks to all that have taken the time to read the comments and help out with opinions.
Old 11-28-2011, 01:37 AM   #16
Pop's C-10
Pop's C-10's Avatar
You may have to bob it to blazer rear end length..use that blazer tank in tha back & mount a 67-72 tank in tha bed against tha cab wall.build a cover it..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 11-28-2011, 07:36 PM   #17
6 Door King
Anyone recognize these wheels? Found a set locally, and seller says they fit Chevy, but I want to ensure I have enough room for the hubs in the front. I am looking for the model number, they are ultra motorsports, 16x10, 6x5.5. If I can pull up the data sheet on them I may save myself a two hour round trip.
"You may have to bob it to blazer rear end length..use that blazer tank in tha back & mount a 67-72 tank in tha bed against tha cab wall.build a cover it.. "
I am not against the idea of bobbing the truck to Blazer lengths, but putting a fuel tank in the usable bed space is definitely out. I still need the truck to function somewhat as a truck. Plus, all my hard work to build a removable filler panel would be wasted if I blocked it with a tank. Will stock pickup tanks (saddle tanks) fit on a suburban frame and clear the body work or will I need a body lift?
Old 12-03-2011, 08:05 PM   #18
6 Door King
Well, no dice on those wheels, the center bore of the wheel is too small to clear the hubs on the front. Glad I checked before I shelled out the dough and got them home.
Old 01-03-2012, 09:24 AM   #19
tallcrown
can you just put a regular No Frills, Truck tailgate on that the way it is?
Will it work?
tallcrown is offline   Reply With Quote
Old 01-04-2012, 07:33 PM   #20
Jonboy
Slots go on anything!
Will it work?
You can for sure on a Blazer, but I am not sure about a Suburban. Of course, since he fabbed it that far, the tailgate would be gravy.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-04-2012, 08:06 PM   #21
joe231
joe231's Avatar
Mmmmm,
A tailgate made of gravy!!
Sounds delish!!
Jon you are a genius!
Best idear eva!!
CHEVY ONLY
Old 01-11-2012, 04:12 PM   #22
truckfan
truckfan's Avatar
gonna watch this
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 01-11-2012, 10:52 PM   #23
68Timber
68Timber's Avatar
Any updates?
John
74 Honda Z50 build
Old 01-11-2012, 11:43 PM   #24
6 Door King
No updates sadly, I have been whoring myself out to others in an attempt to finance my shop expansion. The Sub has been neglected, along with a couple of other projects. Plans are shifting away from the Sub and toward yet another Chevy; a trade for some body and paint work. I am a sucker for neglected trucks, I think I am going to start a home for forgotten and abused pickups. They can live out their lives with a nice view, and have each other's company. I will be accepting orphans soon...
