Old 11-12-2011, 01:01 AM   #1
low 90
low 64 project
little truck ive been working on. 64 c10 5lg, ps, pb, its got a little 305 with a 2004r overdrive i bought out of an elcamino. i have a painless complete wiring kit for the truck along with the painless lockup kit for the overdrive. i the process of bagging it already z'd it 3inches and started on the rear notch till i ran out of wire lol.
low 90 is offline   Reply With Quote
Old 11-12-2011, 01:03 AM   #2
low 90
Re: low 64 project
gonna go back and plate the outside of the z also. welds arent perfect but they never let me down lol! heres a pic of my daily chevy
Old 11-12-2011, 08:31 PM   #3
juanz1947
rusty 66
juanz1947's Avatar
Re: low 64 project
Cool looking good
1947 chevy fleetmaster
http://www.cbforum.net/forum/
1966 chevy c10 long bed
http://67-72chevytrucks.com/vboard/s...d.php?t=439219
1970 chevy impala custom
http://www.layitlow.com/forums/index...pic=349867&hl=
juanz1947 is offline   Reply With Quote
Old 12-15-2011, 09:39 AM   #4
low 90
Re: low 64 project
this is where im at gotta modify the ta crossmember to lay out the rest of the way in the rear. i did a 3 inch z but for some reason the front is not laying out. might have to do spindles i guess. also made my own 2 inch blocks in the rear. i thought a 3 inch z would lay a 27 inch tire but i guess not.
Old 12-15-2011, 08:30 PM   #5
coulter
coulter's Avatar
Re: low 64 project
looking really good so far man.. that thing should lay frame with a 3 inch z and some drop spindles... do you have anything touching the ground right now or is the suspension just bottomed out?
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 12-15-2011, 10:48 PM   #6
low 90
Re: low 64 project
thnx. the rear ta crossmember is touching in the rear i need to modify it. the front is just done though, gonna have to get spindles for sure. its all good that will help me have a lower ride height i like to ride low as possible, that frame not laying is really bugging me though lol.
Old 12-16-2011, 07:07 PM   #7
creep
Registered Loser
creep's Avatar
Re: low 64 project
Very cool trucks. I wish the weather here was nice enough all year round to drive a bagged daily.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 12-17-2011, 12:47 AM   #8
kpc01
Re: low 64 project
Looking good. I'm just across the metroplex from you and will be doing a Z or dropmember soon I hope. Do you have any problems with your track width in the front? That was teh main benefit I saw in the dropmember was to pull the track width in an inch.
kpc01 is offline   Reply With Quote
Old 12-17-2011, 01:19 AM   #9
low 90
Re: low 64 project
creep, thnx! your truck is badass i wanted to leave my stock paint like that but the po sandblasted the whole frontend sucks! and its texas but the other day it was cold enough to freeze my valves up lol. kpc01, it would be cool to have the narrower track up front but i dont have the funds for a dropmember so thats why i went this route. all i see so far is the tires catch the fender on the way down where the inner fenders would bolt on but ill trim that. i like to ride as low as i can and as far as i can tell right now it should turn pretty low.
Old 12-17-2011, 05:09 PM   #10
creep
Registered Loser
creep's Avatar
Re: low 64 project
Thanks! I have an aftermarket crossmember and still had to trim the fenders. It still rubs at full lock when I try cruising lower than my normal ride height. I may try some wheels with less lip and see how they work.
Old 12-17-2011, 08:59 PM   #11
low 90
Re: low 64 project
the wheels i got are off a 88-98 so they are under there alot. onlt thing is you cant run the old style caps. im gonna try to get some trim rings and spider caps or something.
Old 12-17-2011, 09:03 PM   #12
low 90
Re: low 64 project
haha kind of looks like you have the same wheels lol.
Old 12-18-2011, 03:30 PM   #13
creep
Registered Loser
creep's Avatar
Re: low 64 project
They are the same rims. My buddy gave me the wheels from his '92 when he found a set of the factory chrome steelies from a 454 SS model for dirt cheap.
Old 12-20-2011, 10:22 AM   #14
c.brown
c.brown's Avatar
Re: low 64 project
nice solid project looking good your extended cab is real nice !
1966 suburban slammed fuel injected 6.2L
My build
c.brown is offline   Reply With Quote
Old 12-20-2011, 04:47 PM   #15
low 90
Re: low 64 project
thnx
Old 12-20-2011, 10:41 PM   #16
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Re: low 64 project
cool build!!
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 01-29-2012, 01:00 PM   #17
low 90
Re: low 64 project
got some progress done finally. ta crossmember modified got the frame layed out in the rear had to put some little notches in the trailing arms but it down now. got the rear bag mounts in place now i have to gusset them up, box the frame , and do the bridge and some other tube work. lots more to come this is just where it is now.
Old 01-29-2012, 02:25 PM   #18
creep
Registered Loser
creep's Avatar
Re: low 64 project
Did you reinforce the trailing arms where they are notched? It looks like they may be able to twist under load, especially with the notches being between the bags and the axle.
Old 01-29-2012, 03:59 PM   #19
low 90
Re: low 64 project
thats on the list of things to do when i do all the other gussets. im trying to get all the templates cut out to give my buddy who cut all the bag plates much easier than cutting them myself lol.
Old 03-12-2012, 08:42 AM   #20
low 90
Re: low 64 project
little progress
