Old 11-12-2011, 11:31 AM   #1
C15_Sierra
C15_Sierra's Avatar
Gas tank filler hose?
Swapped in an aftermarket '87 20-gal tank (with baffles) to replace my 20-gal carb'd tank and the old filler hose pipe is a smaller diameter than the inlet to the new tank. The hose pipe is prob. as old as the truck (1980) and is thus hard as a rock. Is that the reason why it doesn't fit, or did the '87 tanks come with a bigger inlet diameter, or is it because I'm running an aftermarket tank?
Need to know because I want to go ahead and order the part from LMC, but don't know if I should order for a 1980, 1987, or not at all?
-Steve
1980 GMC C15 Sierra LWB
Dark Carmine Red/Carmine Int
Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011)
Now: 5.3/4L60E, 2.73 12-bolt open rear
C15_Sierra is offline   Reply With Quote
Old 11-12-2011, 12:15 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Gas tank filler hose?
Well the '87's were TBI, I imagine that has something to do with it. Totally different system.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 11-12-2011, 12:24 PM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
I'll check at work today and let you know tonight on availability of oem parts.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 11-12-2011, 12:30 PM   #4
C15_Sierra
C15_Sierra's Avatar
The only differences are the tank baffles (to keep the fuel near the pickup), and the sender has an in-tank pump. I'm running a 5.3 in my truck
Cool, thanks for your help!
-Steve
Old 11-12-2011, 07:21 PM   #5
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Just did a swap of an 84 tank into my 77. My 77 has a inlet hole of 1 and 1/4 inches and the 84 is 1 and 5/8. I believe 82 and up were 1 and 5/8. Check ebay for 87 gas tank and usually they say what size the inlet necks
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 11-12-2011, 11:20 PM   #6
C15_Sierra
C15_Sierra's Avatar
Thanks for that...for some reason I didn't think to check the diameters of the different tanks (I still have my old tank kicking around) with my calipers
-Steve
