Old 11-12-2011, 02:59 PM   #1
Phil750
gauge housing
I am trying to find a new instrument gauge housing. The screw holes are broke and stripped. This is for 1986 C-20 pickup.
I have been to every site on line with no luck. What are my options if any.
This housing is where the circuit board attaches.http://67-72chevytrucks.com/vboard/i...ilies/waah.gif
Thanks! Phil
Phil750 is offline   Reply With Quote
Old 11-12-2011, 06:37 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: gauge housing
check out some of the guys in the classifieds parting trucks...
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-12-2011, 09:10 PM   #3
dale3goodwrench
Re: gauge housing
Post a pic of what exactly you need. I might be able to help you out.
dale3goodwrench is offline   Reply With Quote
Old 11-12-2011, 11:20 PM   #4
J Knight
J Knight's Avatar
Re: gauge housing
Sounds like you need the white plastic gauge cluster housing to put your gauges and printed curcit on right?
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 11-12-2011, 11:26 PM   #5
Cramitthefrog
It's always something
Cramitthefrog's Avatar
Re: gauge housing
I have a few also post up what you need, gauges no gauges clock etc.
Cramitthefrog is offline   Reply With Quote
Old 11-13-2011, 11:09 AM   #6
hatzie
Moderator
hatzie's Avatar
Re: gauge housing
You can probably salvage the housing unless the screw towers are split completely away from the housing.
  • Carefully drill out the damaged holes till a plastic rod roughly twice the diameter of the screw can barely be inserted with model cement. The sprues from a model car boat etc kit can be used for this. Chuck a short piece in a drill and sand it down to the diameter you need. Cut a little longer than the holes you will be filling.
  • Set it aside in a warm place till the day after tomorrow. Now that the cement is really dry carefully whittle the patch down to the top of the damaged tower with sand paper.
  • Re-drill the holes out to pilot diameter for the original screws. Measure the top and bottom of the threads midway up the screw with a dial caliper and pick a drill bit that is roughly halfway between the two diameters (slightly smaller is better than slightly larger).
  • Carefully screw them back in by hand. Stop and turn backwards at least 1 full turn if it feels too tight. Don't tighten beyond 1/16 of a turn past contact with the gauge faces or you'll strip them again.
