Truck Nut
![]() Join Date: Jun 2007
CL 88' 4x4 Burb I just picked up.
Wasnt really needing this thing but....I never owned a 4x4 and wanted one. Its an 88', 350 tbi, 400TH, 3/4 ton, 4x4. Unsure of which transfer case it has. Ive had it a week and just had time to drive it today. It needs two tires and those dam running boards removed. Needs lock out hubs too. I have got a full floater for it also. After winter I will be pieceing a 6-8" lift together with 16.5's and military 37's.
Any suggestions on a cheap lift would be appreciated. Im thinking 1 ton springs front and rear with those B52 spring perches up front. Will not be a daily driver. Shes not pretty, but I bought it right. I have everything and then some to make it nice, but probably leave it like it is. Drove it through the woods and was so much fun!!!
Tony Kee Texas Square Bodies Last edited by texassquarebodies; 11-12-2011 at 04:05 PM. |
Re: CL 88' 4x4 Burb I just picked up.
If the price on the windshield is right, you did buy it right! Looks like a great place to start an obsessive restoration process!
1954 3100 Nova Subframe, Pontiac Posi, roller for now1967 C-10 SWB 350/350/Posi. Soon to be Crew Cab! 1978 Crew Cab Dually roller 1982 C-30 Rollback, 454, 4 speed 2004 K1500 Suburban Z71 5.3 Kid Mover Last edited by 6 Door King; 11-12-2011 at 07:37 PM. Reason: spelling |
Yeah, If you paid $50 for that thing you got a heck of a deal no matter what you plan to do with it. It needs some TLC, but looks like a solid truck to start with.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
do a B-52 swap up front and a shackle flip in the rear. That will net about 4" of lift. If you want to go higher get lifted leaf springs.
86 Suburban 2WD = rolled it and totaled it ![]() 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. ![]() 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
Truck Nut
4" of lift isnt going to clear 37's. Not cutting anything. This is a low budget build. Going to use CL for used lift parts. Only things I will buy new are shocks and a dropped arm and maybe longer brake lines.
Tony Kee Texas Square Bodies |
Chevys Kick A$$
Awesome score looks like with some tlc it would make an awesome driver. Good luck on the build and have fun cruising it around as well
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
4in suspension and 3in body will clear 38.5s without cutting because that's what my setup is :-p but not everyone likes body lifts anyways the transfer case is probably the 208 or 241 can't remember when they switched and is that a conversion of some sort I usually see the wood grain interiors on conversion
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
I'l give you $ 60 lol
its an NP 208 2.7 low chain drive and an aluminum case unless you have 600 Hp and 44's its a fine t-case dont let anyone tell you different nice score now go at it with a gallon of flat black and make it match or do what i do and cover it in mud till you cant tell the brand much less the colour
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long 1987 IrocZ-28 525 horse/567 Lb Tq 383 1976 K30 on 39.5s One wheel drive thanks to a np203 ![]() and some K5's lol |
