Old 11-12-2011, 05:14 PM   #1
FLcustom10
Transmission leaking at Speedometer cable
I had the transmission rebuilt years ago and it leaked immediately at the speedometer cable. I took it back multiple times, but got no satisfaction. They just said I wasn't driving it enough and that would make it leak.
Do you think I need a new speedometer cable or can you make a recommendation on something to seal it?
FLcustom10 is offline   Reply With Quote
Old 11-12-2011, 05:44 PM   #2
hjewell2
hjewell2's Avatar
Re: Transmission leaking at Speedometer cable
This might work depending if the threads a crossed or not. First remove spedo cable and clean male threads including removing the RTV with a can of carb clean. Do the same thing to the inside threads and pay attention to the collar where it spins on the cable clean it good if you re-install and hear grinding of dirt on the threads and can wiggle the cable behind the collar and see movement there re-do it. Had same problem on many cars and dirt was the problem every time tranny was pulled. There is no o-ring is in there for the collar.
Hope this helps you.
hjewell2 is offline   Reply With Quote
Old 11-12-2011, 06:17 PM   #3
66skylarkpost
66skylarkpost's Avatar
it has nothing to do with the cable . u need to pull the insert and gear,then replace the seal thats in the inside, sometimes held in with a wire ring and the o ring on the outside . u might need a new gear . since they are plastic, they will wear a groove where the seal rides easily
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 11-12-2011, 06:30 PM   #4
66skylarkpost
another pic ... i tried to highlight the gear where the seal wears
Old 11-12-2011, 07:15 PM   #5
FLEET72
FLEET72's Avatar
Seems to me that a transmission shop should know this. I'd be leery about utilizing them in the future.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 11-12-2011, 07:24 PM   #6
hjewell2
hjewell2's Avatar
Very true--this should have been replaced during rebuild.
Old 11-12-2011, 08:42 PM   #7
FLcustom10
Thanks guys. I fully agree -- I will not be using that transmission shop again and I will advise others against them also.
Old 11-13-2011, 09:33 PM   #8
hayhauler71
hayhauler71's Avatar
Maybe you can advise your transmission shop
Fuzzy
hayhauler71 is offline   Reply With Quote
