Old 11-12-2011, 06:25 PM   #1
jjmorrse
Manual steer for 2wd 1500?
I have an 89 burb. It is a 1500 2wd. I am thinking of converting to manual steering. I see boxes in lmc but they show earlier years. I would also need to address the serpentine belt. Anyone done this conversion. How much juice will i need to steer the beast? Plan on keeping lt road truck tires on it. Thanks for any input.
jjmorrse
86 C30 crewcab big dooley. 454- 400
jjmorrse is offline   Reply With Quote
Old 11-12-2011, 11:23 PM   #2
Psycho71
Psycho71's Avatar
Re: Manual steer for 2wd 1500?
Once you get all the components swapped out it shouldn't be too bad to turn. I'also look at the steering wheel diameter of the older trucks w/o PS. Most of the non-PS vehicles I ever saw had a larger wheel to make turning it easier.
Mind if I ask why you'd want to get rid of the PS in the first place?
I'm sure others here will chime in soon enough on the viability of swapping the parts out.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 11-13-2011, 02:32 PM   #3
jjmorrse
I blame it on my history. A 71 camaro with manual disks and a 54 plymouth with a flathead. I get used to very little clutter. Washer and cruise already had to go. floormats, out. I am really a very sick person. AC is staying, because it hit 107 last summer here in tx, but I have thought of getting rid of the rear AC. I even caught myself drilling lightening holes in the inner fenders.
This time, the steering box started leaking, just after I replaced the hoses, so I thought I would look into the switch.
jjmorrse
Old 11-16-2011, 11:18 AM   #4
jjmorrse
Anyone addressed the power steer pulley on this?
jjmorrse
Old 04-23-2012, 06:29 PM   #5
Ford Assassin
Ford Assassin's Avatar
Another run at the top...
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
