Distributor bolt won't stay tight
I have a new HEI distributor in my 454 BBC. Every 300 to 500 miles, it seems the tighten down bolt to my distributor will loosen and the truck will not start. Any help on how to fix this problem?
Re: Distributor bolt won't stay tight
I have heard of this problem before. I would try LocTite.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
The hold down bracket is it OEM or chrome after market? If it is a aftermarket throw it away it will never stay tight had this problem on a small block I had, drove me mad almost striped the manifold out trying to keep it tight. I hope this helps?
Corsair
"The Can't Family Lives Across The Street" |
Active Member
![]() Join Date: Jul 2007
I've never had the problems but first and foremost try the loctite then maybe a new bolt. Make sure it's completely clean of oil and grime for the loctite to work properly. If the threads are wallowed out I would think you may have to retap to the next larger size or heli coil it.
Active Member
Buy a good aftermarket unit with a stud and nut rather than a bolt
Loctite the stud into the manifold - buy a nut with a captured tooth style lock washer and go to town - it will serve you well with no risk of damage to your manifold
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
![]() ![]() Join Date: Dec 1999
Or use a stock hold down bracket. And use a bolt with a LOCK washer on it. Your problem is vibration. The washer should absorb it and keep it tight.
Had this issue before, and thats how i cured it.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
#7 | ||
Thanks for everyones help and I will definetly use LocTite this time. |
everything 1968 said.
