Am I missing a seat part?
This just dosent look right. A hex seat adjusting nut that sits on a round hole? Looked all over the pLace and cant find a picture of how this seat adjusting screw is supposed to look. Any pictures or referance to a diagram would be appreciated.
Re: Am I missing a seat part?
It is kinda hard to tell from your pictures what I am looking at. If it is for the part that leans forward (seat back), then yes - it looks like you should have a couple of nuts
![]() First 2 pictures, drivers side. 3 picture passenger side. Hope this helps. Keith |
Thats it LiL. Thanks for the pics. Very helpful. Seems like the 2nd nut should be a little larger than the single nut on mine. Or, a washer the size of the surface where the nut sits and a small nut that would go through the hole.
Posted via Mobile Device |
![]() Join Date: Dec 1999
You should have a wing nut on the very bottom on both sides
If you have a wing nut on the bottom then the seat back won't lean forward. Mine is a 1968 chevy bench seat.
Keith |
My 67 came with one factory I figure for it to be easy to remove when you needed to get behind your seat and so you want eat the dash as bad if you wreck???
#8 | |
![]() Thanks, I think I will find a wing nut to put on there. My dash does look kinda tasty but I sure wouldn't want to eat it!! ![]() Keith |
fat old dude
![]() Join Date: Feb 2010
yeah a wing nut to prevent the 67-68 seats from flying forward when u get to a stop
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
Hey Keith, My 67 came from my Great Uncle whom bought it new but I did remove the passenger side one so if I needed behind the seat I would just have to remove the one on my side and not walk around the truck.
Thanks to Tim Christian, Heeroyue2002, and Arl37, I learned something new today. Yeah I would have been in for a rude surprise if I got into a fender bender and the seat goes flying forward. I still only have the lap belts too!
![]() Thank you! Keith |
thanks everyone for your help
