Old 11-13-2011, 04:00 PM   #1
grs
Map sensor
What brand map sensor do you think is the best to buy.
grs is offline   Reply With Quote
Old 11-13-2011, 05:21 PM   #2
Zane M
Re: Map sensor
AC Delco
Zane M is offline   Reply With Quote
Old 11-13-2011, 06:00 PM   #3
grs
Re: Map sensor
Originally Posted by Zane M View Post
AC Delco
Thanks, I looked on web sites , but can't find anyone that sells a Delco.
Old 11-13-2011, 08:34 PM   #4
Zane M
Re: Map sensor
Interesting. I googled "AC Delco MAP sensor" and got a ton of hits. You would have to filter it down based on what part # you need(relating to your year and model), but it sure seems like there are Delcos available.
Otherwise, I would go for whatever brand NAPA sells. However, it has been my personal experience with any type of sensor, if you can't get OE, you are rolling the dice on how long it will last, or if it will work properly at all.
Old 11-13-2011, 08:48 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Map sensor
Another vote for ac delco from me.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-13-2011, 09:48 PM   #6
grs
Re: Map sensor
I googled Ac Delco. I did find one co. I will call them. NAPA sells Delphi brand. I do want an AC Delco tho.
Old 11-14-2011, 08:34 AM   #7
hatzie
Moderator
hatzie's Avatar
Re: Map sensor
Delphi electronics was a merger of GM ACG and Hughes AC Delco electronics. I wouldn't have a problem buying Delphi sensors.
Old 11-14-2011, 08:51 AM   #8
grs
Re: Map sensor
Thanks. I was thinking that Delphi was a good brand.
Old 11-17-2011, 06:02 PM   #9
grs
Re: Map sensor
Turned out the EGR valve was bad. The code that came up said the MAP, or EGR was bad. I replaced the EGR, and the code never came back on yet.
