Old 11-13-2011, 04:37 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
Blower motor switch question
My blower motor hasnt worked on my truck for years now and today I decided to give it a look over. I put a checked the hot wire that goes to the plug that goes onto the back of the switch and it barely has any juice going though it (the tester had a very faint red light). I traced the wire all the way to the fuse box and I looks impossible to find not only the wire in the box but the problem (electrical is not my strong point). Would it be possible to splice that wire in with one of the many wires in the bundle that gets power when the key is on?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 11-13-2011, 06:13 PM   #2
67sss
67sss's Avatar
Re: Blower motor switch question
check the ground on the blower motor first. run a wire from the ground of ur battery to the blower ground, see if that helps. most electrical probs are the ground. my .02 worth.
67sss is offline   Reply With Quote
