Old 11-13-2011, 05:33 PM   #1
matts86chev
matts86chev's Avatar
Changing Tranny fluid and Replacing seals?
Alright, so I have an '86 c10 that got a new tranny last May before I bought it (got the receipt from previous owner so I know it actually did) and I've put probably around 30k miles on it and its now starting to shift higher and higher in the RPMs and a bit rougher. I was figuring the easiest and best fix would be to drop the pan and change out the fluid and some seals. Is there anything else I should check for or look at replacing while I am in there or any tips I should know about? AT's are currently outside of my realm of knowledge!
1986 Chevy C10 305 5.0L Work in progress...
matts86chev is offline   Reply With Quote
Old 11-13-2011, 06:58 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Changing Tranny fluid and Replacing seals?
If it's a 700R4 you should check the TV cable adjustment first.
