Old 11-13-2011, 09:23 PM   #1
Spindle Change Question
I have a set of spindles, rotors and calipers from a 1978 Chevy C10. What do I need to use them on my 70 C10?
Just use stock 70 A-arms and ball joints for the 78?
Tie rod ends for the 78?
Thank you.
Old 11-13-2011, 09:35 PM   #2
mooneyes
mooneyes's Avatar
Re: Spindle Change Question
...if I remember correctly u need the outer and inner tie rods from the 78 and I know I used 72 ball joints cause I already had them bought..just had to use a few washers cause the cotter pin hole was lower..
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 11-13-2011, 09:49 PM   #3
Daves70
Daves70's Avatar
If you have the spindle for the 1.25" thick rotor you use the 78 upper and lower balljoints.You will need 78 outer tierods and use your 70 outer tierods for the inners and get an adapter sleeve from cpp to connect the two.Did it on my truck and worked great.
Daves70 is offline   Reply With Quote
