Old 11-14-2011, 03:27 AM   #1
leddzepp
Moderator
leddzepp's Avatar
Parts lot: A/C controller, radio knobs, etc.
Here is a small parts lot for $40 Shipped in the US.
Driver quality A/C contoller. Should clean up nicely.
Tailgate hinges/trunions.
Rear taillight/back-up light housings. Driver taillight lenses.
Deluxe radio kobs.
67/68 floor jack/tool mounting hardware.
Driver 69-72 console ashtray.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-14-2011, 05:14 AM   #2
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
Re: Parts lot: A/C controller, radio knobs, etc.
any broken levers on ac... how is lens on it.. .how bad pits... and how is inside of ashtray...either way "I WILL TAKE IT" just clarify so I have a head start zep... thanks buddy
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 11-14-2011, 01:45 PM   #3
leddzepp
Moderator
leddzepp's Avatar
no broken levers, no pitting, just dirty. can be taken apart and cleaned up. the inside of the ashtray has surface rust. i will get more pics and post late tonight when i get home. thanks.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-14-2011, 02:58 PM   #4
HeavyMetalChevy
Just a Member
I will take it... SOLD Thanks buddy
TH400(3rd)
Old 11-15-2011, 01:59 AM   #5
leddzepp
Moderator
leddzepp's Avatar
Duane- Here are some more pics. I took a closer look and cleaned up the face a bit. In the first pic, you can see there is one pit or bubble present. There are no others on the face, but there are some along the top right side, which is not seen when installed. Also is a pic of the inside of the ashtray. I have some other small parts that will fit in the box, that I have no use for, and will toss in. Gas pedal, radio/speaker mounting brackets, woodgrain trim piece, and a tilt column shift lever in perfect shape from a van (shorter than a truck shifter, and nice to use when running a smaller than stock steering wheel) Let me know if you still want this stuff. Thanks.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-15-2011, 02:14 AM   #6
HeavyMetalChevy
Just a Member
Yeah awesome.. .I am getting a nice tilt column here shortly and I was already planning on using a van lever because I knew they were shorter.. .Sweet Zep... That gas petal is Cheyenne or Custom deluxe correct because of the chrome trim??? Either way SOLD payment coming sir.
Duane
TH400(3rd)
Old 11-15-2011, 02:30 AM   #7
leddzepp
Moderator
leddzepp's Avatar
the pedal is from a 67 CST. i believe it will work on 67-71 trucks, as 72's are different and use a throttle cable as opposed to linkage.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
