Fabricate till you "puke"
02 silverado,inner tierod ends
I have an 02 1500, 2wd that needs inner tierod ends. The truck has 165,000 on the clock, so my ? is ....Would it be more economical(in the long run), to just replace the rack & pinion assy,vs just replacing the inner tierod ends? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Has more rust than truck...
Re: 02 silverado,inner tierod ends
If you have no leaks, noises or other concerns with your current rack, I would replace the tie rod ends and bellows and call it a day.
Will that require a drill fixture, to remove the pins(like on most front drive apps)? crazyl
You can use a "inner tie rod removal tool" most auto stores have it as a loan-a-tool. Or a pipe wrench and vise grip have been used.
http://67-72chevytrucks.com/vboard/s...d.php?t=469722 |
Many thanks
