11-14-2011, 01:51 PM | #1 |
easier drop
I am not here to slam my truck to the ground, I do like some clearence, So wit that in mind. Is there some rear shocks I can get to lower the back end a little bit, and what about the front a little bit. Keep in mind Its all stock 69 c10 longbed. and Im just wanting a better stance and look.
11-14-2011, 02:28 PM | #2 | |
Re: easier drop
11-15-2011, 09:56 AM | #3 |
Re: easier drop
2.5" drop spindles are the best place to start since they drop your truck but preserve the ride. Shop around you can get them for around $250.00
If your truck is on coils in the rear get a set of bags hook them up to a schrader valve and now you can control the stance of the truck. Boris on this board way2low offers this combo of 2.5 spindles and bags for $319.00 that is not too expensive and is the one of the best ways to start. If your truck is on leaf springs just get a shackle kit and drop the rear.....or move the leaf springs under the rear end instead of over it. JMO Kieth |
11-15-2011, 11:49 AM | #4 | |
Happy to be here
Re: easier drop
11-15-2011, 12:50 PM | #5 | |
Re: easier drop
x2. For minimal drops (</= 2"), it's not worth the additional investment of discs up front ($500-ish for spindles + swap parts) & air in the rear. Another low cost option I didn't post for the rear coil applications was lowering blocks.
