Old 11-14-2011, 03:11 PM   #1
hopped up
hopped up's Avatar
brake light switch question
bought a new brake light switch for my 64 c10. but when i was gonna install it i noticed i dont have the connection/plug that connects to the brake light switch. prob the reason i dont have rear lights at all. my question is what is that connector called , ive been trying to find it but not knowing the correct name has made it difficult. if someone has a pic of it too, would be very usefull. its for a stock braking system if that matters.?thanks
hopped up is offline   Reply With Quote
Old 11-14-2011, 05:01 PM   #2
brawley
Easy Does It
brawley's Avatar
Re: brake light switch question
should just be called a brake light switch, mounts between steering column and parking brake lever. heres a pic. has two prongs on end for wiring.
brawley is offline   Reply With Quote
Old 11-14-2011, 05:53 PM   #3
hopped up
hopped up's Avatar
thanks, but i was reffering to what connects to the 2 prongs on the brake light switch
Old 11-14-2011, 06:28 PM   #4
64shortbox
64shortbox's Avatar
hopped up,
I still haven't found that pic of the brake light connector but here's the pic of the courtesy light connection I promised you.
Terry
64shortbox is offline   Reply With Quote
Old 11-14-2011, 06:44 PM   #5
jonathan-m
I just used generic female connection ends for that, since mine was missing as well.
Rockin' a '66 and loving every minute of it
jonathan-m is offline   Reply With Quote
Old 11-14-2011, 06:52 PM   #6
hopped up
hopped up's Avatar
thanks for that pic shortbox
Old 11-14-2011, 09:17 PM   #7
Woogeroo
There are two separate plugs, one on each wire that slide onto the metal ends of the stop light switch.
If you have to, you could use slide on connectors of the same size.
Other than that, you'd have to buy that part of the harness I am guessing.
The fun part will be adjusting the switch to where it is 'just right' !
-W
Woogeroo is offline   Reply With Quote
