Old 11-14-2011, 07:18 PM   #1
stroker87
87 ugly transmission support brace any options?
I'll be putting the engine back in my truck over the winter and want to have the exhaust redone I hate the one pipe over and the other under the trans support is there any options other then making one? I want to clean up the pipes any way i added and removed/installed mufflers, H pipes & etc. now that I know whats going to stay I want it to clean it up
as you can see it the exhaust looks horrible
stroker87 is offline   Reply With Quote
Old 11-14-2011, 07:34 PM   #2
J Knight
J Knight's Avatar
Re: 87 ungly transmission support brace any options?
73-76 trans crossmembers are semetrical, the same as your current crossmember on the right side but on both sides of the 73-76. I hope this makes sence.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 11-14-2011, 07:38 PM   #3
stroker87
yes made sense
i'll look in it thank you
been searching cant fine any some one have a link for the one hes talking about?
Old 11-14-2011, 08:14 PM   #4
J Knight
J Knight's Avatar
Re: 87 ugly transmission support brace any options?
Here is mine out of a 74 C10. It also has top braces lik your right side does. I plan on using this for my 82 wich has the over and under crossmember like yours.
John
Old 11-14-2011, 08:38 PM   #5
stroker87
thats what I want! I've been looking and found some aftermarket ones but they dont have the frame braces just pretty much a straight peace that only bolts on to the bottom of the frame
i'll keep looking for one like you have
thanks for the pictures
Old 11-14-2011, 08:49 PM   #6
my4by2
my4by2's Avatar
Fab one up yourself, or find a shop that can do it for you. That way you'll get the best fit & the overall look you're after in one shot! Here's the one they built for my truck.
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 11-14-2011, 08:53 PM   #7
stroker87
I looked in to getting one built locally the guy wants $325 witch just seams a little high to me plus I have a lot going on with the truck and want to put the money in other areas of the build who knows maybe I'll brake out the welder and give it ago if I can fine one like J Knight posted
Old 11-14-2011, 11:54 PM   #8
SCOTI
SCOTI's Avatar
Aftermarket trans x-members for 67-72's will work. You might have to drill a new hole or two, but they fit within the frames. They'll even work on the taller frame of a C30 w/a little tweaking....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-14-2011, 11:58 PM   #9
SCOTI
SCOTI's Avatar
That x-member started out as one of these from Early Classic Enterprises....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-15-2011, 12:03 AM   #10
stroker87
I was told that one would not work with my 700r4, bottom of the trans is about even with the frame
any of the aftermarket cross members would have to be modified ????
Old 11-15-2011, 12:27 AM   #11
SCOTI
SCOTI's Avatar
This is a side by side comparison of the OE trans x-member & my 'modified' ECE unit. I fabbed & added the mount to the main 'center' tube of the x-member. You can see I built it to the same height as the OE unit from my 89 C3500 (it's a CC C30) that came w/a 454/th400. That's a Energy Suspension poly mount on top of the 'mount' I added. Using the OE x-member, that same poly mount would simply sit on the top of it....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-15-2011, 12:29 AM   #12
stroker87
This is a side by side comparison of the OE trans x-member & my 'modified' ECE unit. I fabbed & added the mount to the main 'center' tube of the x-member. You can see I built it to the same height as the OE unit from my 89 C3500 (it's a CC C30) that came w/a 454/th400. That's a Energy Suspension poly mount on top of the 'mount' I added....
thats second pic makes me think the guy didnt know what he was talking about?
how much is that mount?
Old 11-15-2011, 12:33 AM   #13
SCOTI
SCOTI's Avatar
$90 powder-coated, $80 raw steel....
http://www.earlyclassic.com/catalog.aspx
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-15-2011, 12:39 AM   #14
gofastbobby
gofastbobby's Avatar
Do you have any more pics of the exhaust on your truck? I like the concept. What drivetrain are you running?
--bob o
'76 C10 "BIG10" SWB 454/400 Mostly Stock.
gofastbobby is offline   Reply With Quote
Old 11-15-2011, 12:47 AM   #15
SCOTI
SCOTI's Avatar
This pic makes me think the ECE x-member might work as is. Compare where the bottom of the frame-rails lip is vs your trans mount. Look how the ECE trans mount flange is about even w/the bottom of the frame rail lip (where it bolts in is on the frame-rail lip)....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-15-2011, 01:10 AM   #16
stroker87
SCOTI thanks I'm going to give that one a try to see if it will work
--bob o
383 stroker EFI, 700r4 & 12 bolt 3.73 gear
only have a couple from when the cutouts was installed the pipe exit right under the plate in the center of the roll pan (no picture with the tips sorry)
Old 11-15-2011, 03:00 AM   #17
gofastbobby
Awesome. Thanks man.
