Old 11-14-2011, 09:03 PM   #1
A69C10
Do flex?
Had to change a flat the other day and when I jacked up the truck, it had massive chassis flex. And to get started I lifted on lower a arm not chassis. anybody else have this issue. not trying to make a g machine. but this much twist is torque loss at the wheels.
A69C10 is offline   Reply With Quote
Old 11-15-2011, 12:33 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Do flex?
These old trucks were built to flex If I drop my Longhorn into a "cloverleaf", that states 25mph....runnin 55 goin in, & 75 coming out. turnin
right, but steerin left....she is long, & she slides slow & easy(take 2 lanes totally crossed up), & I have been there crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-15-2011, 11:50 AM   #3
OJ1988
Just a car guy
OJ1988's Avatar
Re: Do flex?
The frame is built like a ladder. It is easy to twist. And triangles to make it stiffer.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 11-15-2011, 01:59 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Do flex?
Almost all ladder frame vehicles flex.They usually use some of that flex to absorb road fluctuations.So when you see a drag racer that doesn't run that quick but has a roll cage,that's why.They use the cage to create rigidity in the frame.Adding triangles will stop "racking" but not actual flex.Unless they are triangulated to help strengthen and solidify the cage.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
