Old 11-14-2011, 09:14 PM   #1
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
removing engine and trans from a 72 k20
Need to remove a locked up 350/350th from a 72k20. Anyone have a pic of the mount between trans and transfer case? So much grease under there I cant see where to scrape for the bolts. Also any tips and will this be harder with locked up engine? Trans needs rebuilt also.
Thanks in advance,
Jud
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 11-15-2011, 12:13 AM   #2
OrrieG
OrrieG's Avatar
Re: removing engine and trans from a 72 k20
My drive train is from a 74 K10 with a 203/350. I think 205 is similar. In this photo you can see there are 5 bolts from the transmission side of the adaptor thru the adaptor to the transfer case. Obviously you need to have the crossmember, shifter, etc. removed. The transfer needs to pull straight back so it disengages from the adaptor and the shaft clears. I have always removed the transfer first then the transmission because of the weight. The transmission bolts to the engine with 3 bolts per side if I remember right. It needs to pull straight back off of the alignment dowels. Don't forget to unbolt the torque converter first so it comes with the transmission or you get to clean up a lot of fluid. Drain both first to minimize a mess.
OrrieG is offline   Reply With Quote
Old 11-15-2011, 12:17 AM   #3
Vintage Windmills
Vintage 4x4s
Thanks for the info! I can't unbolt the torque converter though since the engine is locked
Old 11-15-2011, 08:43 PM   #4
OrrieG
OrrieG's Avatar
Looks like you get to wrestle the trans out with the engine.
Old 11-16-2011, 08:07 PM   #5
Vintage Windmills
Vintage 4x4s
Any chance I can also leave the t case on, remove crossmembers, mounts, and just drop everything out the bottom? I have a two post lift. I'd like to leave it all together for pressure washing prior to disassembly.
Old 11-16-2011, 08:39 PM   #6
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I dropped mine out thru the bottom on my K-30 awhile back using my Gray end lift...I didnt have my front axle in at the time tho. Clearing your front axle is the hard part but with a 2 post lift you should be able to do it. Remove your tires and wheels so you can drop low to the ground..then use a cherry picker to lower the motor and trans the rest of the way..as soon as you clear the firewall start rolling it back to clear your axle..having a good tilt to the rear will help a lot plus remove the distributer and carb before hand will help.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 11-16-2011, 08:58 PM   #7
Vintage Windmills
Vintage 4x4s
Awesome, thanks I'm going to give it a shot after seeing this! Nice truck by the way, i remember seeing pics of it before!
Old 11-17-2011, 12:42 AM   #8
Psycho71
Psycho71's Avatar
You could just unbolt the transmission from the block, let the converter slip out of the pump, and pull the engine by itself, then drop the trans and x-case out the bottom. I just did the same thing with a locked up engine in my burb last fall. I was rebuilding everything anyway, so i got it all out the fastest/easiest way i could think of.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 11-17-2011, 09:35 AM   #9
chop_shop
Thats what i would do...
chop_shop is offline   Reply With Quote
Old 11-17-2011, 09:37 AM   #10
Vintage Windmills
Vintage 4x4s
That might work and everything would still be closed up enough for a pressure wash. I'd just have to plug the end of the torque converter.
Old 11-17-2011, 09:49 AM   #11
chop_shop
when you pull it out you can unbolt the converter from the flywheel. When the trans is not in the way you can get to the bolts. I would pull the converter before you pressure wash it.
