Old 11-15-2011, 11:48 AM   #1
Scottsdale Doc
350 Transmission
I have a 85 Scottsdale and the new problem I am having is this, when the trans is put in gear the engine vibrates. It does not matter what selection I make forward or reverse.
The trans was overhauled w/new torque converter and only has about 80 miles on it.
Has anyone had this problem or know what this could be?
Last edited by Scottsdale Doc; 11-15-2011 at 11:49 AM. Reason: left out my question
Scottsdale Doc is offline   Reply With Quote
Old 11-15-2011, 12:17 PM   #2
Pop's C-10
Pop's C-10's Avatar
Re: 350 Transmission
Could be you tune is off...unless there is something wacky with your flywheel or torque converter
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 11-15-2011, 12:22 PM   #3
Scottsdale Doc
Thanks do you know how to determine if the torque converter is bad????
Old 11-15-2011, 01:26 PM   #4
rs72z
rs72z's Avatar
It would vibrate all the time if it was the converter. At least any of them i have seen vibrate done it all of the time.
Sounds like a miss or maybe carb half stopped up or vacuum leak.
Does it change with rpm?
rs72z is offline   Reply With Quote
Old 11-15-2011, 01:44 PM   #5
Scottsdale Doc
Thanks= It only vibrates when you are stopped and as soon as you accellerate (or start moving) it stops.
The engine runs pretty smooth when it is in park. I will check the vaccum just to be sure.
Old 11-15-2011, 01:46 PM   #6
James McClure
One shot, one kill.
RS 72 is right. A bad converter or flywheel will vibrate without reguard for in or out of gear. If it is smooth in neutral or park the coverrter is ok. Is the vac modulator hooked up properly? How about the dist cap? I can't count the number of times I half knocked the cap off pulling a trans. Check secondary wireing also. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 11-15-2011, 07:56 PM   #7
Pop's C-10
Pop's C-10's Avatar
then you carb or timing is off..or you knocked a vac line off somewhere..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 11-17-2011, 01:58 AM   #8
rayfinseats
Broken engine mount or trans mount? Have someone watch under the truck as you power brake it.
rayfinseats is offline   Reply With Quote
Old 11-17-2011, 06:13 AM   #9
lurch115
lurch115's Avatar
another thing to check is that all the bellhousing bolts are tight. have also had loose torque converter bolts do something similar. would vibrate in low rpm cruising speeds. tightened them up and it went away.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
