hood mounting with no inner fenders???
so the inner fenders on my truck a rotted pretty bad and are really expensive new. so seeing as im lowering it and running big rims i was just going to take them out but the hood hinges off the inner fenders. what did you guys with no inner fenders use to hinge your hood? pics would be great
Re: hood mounting with no inner fenders???
I think markeb01 might run without inner fenders. He usually monitors this section pretty closely, but you might PM him.
yes this would be some good info
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Porterbuilt makes some hinges you might want.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
wow those porterbuilt ones are 265 im building on a budget. anyone have some pics of modified stock ones or a cheap diy set??
PORTERBUILT STREETRODS also makes a cheaper version that uses the stock hood hinge.
Tony from Norcal Posted via Mobile Device |
Did someone say cheap?
Nate's hinges are worth every penny, though.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
![]() Join Date: May 2007
you always pay for quality, and porterbuilt is very high quality.
I will be using a buick forward tilt hood hinge like others on here have.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
tons of inner fenders on ebay! what going to hold your outer fenders??????????????? (not to mention rad support and headlights.
Not saying the porterbulit are bad just at close to 300 bucks ill just get new inner fenders
