Old 04-18-2003, 09:08 PM   #1
chevy lover
HMMMM Chevy
chevy lover's Avatar
flipped shackles?
I found these and was wondering if anyone has used these.
http://www.off-road.com/chevy/review...ins3_small.jpg
found them here
68 Chevy C10 swb(under construction)
82 GMC K1500 6.2l diesel (daily driver)
77 Chevy K30 frame (only thing left is axles and trans/transfer)______________________________
Mike
chevy lover is offline   Reply With Quote
Old 04-20-2003, 04:45 PM   #2
Chevy409
Giddy up giddy up...
Chevy409's Avatar
Just torch a hole in the bottom of your existing hangers, flip the shackle, and you've got a four inch lift.... ok, well, there's a little more work involved than that, but that's what I did and worked great. Just make sure to add some braces after for the lost support. FREE is always a good price
72 with 69 grille and custom 73-87 stepside. BIG BLOCK 409, SM465, NP205, 3/4 axles slung under a 5" lift, 3"bodylift, 112" frame, and 35inch Pro Comp X-terrains... "BUILT NOT BOUGHT" Here's the site...
Chevy409 is offline   Reply With Quote
Old 04-20-2003, 09:31 PM   #3
Mike C
Mike C's Avatar
Yukon Jack has the shackle reversal on his 3/4 ton and is quite happy with them. I'm sure he'll chime in here.
I recommend new springs, however.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-20-2003, 11:02 PM   #4
TX_Mudder
I have something very similar, the Echobit shackle flip. It rides better than simply lifting the rear with springs.
I like it and would recommend it.
-- Mike
TX_Mudder is offline   Reply With Quote
Old 04-21-2003, 01:55 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
That looks like the shackle flip from www.offroaddesign.com that I am using. I'm pretty happy with mine but beware that your rear axle moves closer to the front of the rear fender well.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-21-2003, 07:02 PM   #6
chevy lover
HMMMM Chevy
ok i have 31's on the truck now. but if the axle moves forward would I be able to get the 35's on the truck. what size you have under your truck Yukon Jack?
Mike
Old 04-22-2003, 09:43 AM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
Originally I had just the shackle flip gaining 4" and the 35's fit fine.
