Old 11-15-2011, 10:56 PM   #1
SchnorrCS
Front end jacking
Sorry about the super newb question.....
All my trucks have been 4x4, and I'm scratching my head on how to jack the front end up to put her on jack stands....
Right now, I'm leaning towards under the LCA/spindle. Any better thoughts?
While I'm at it, does everybody just put their jack stands under the frame rails just behind the motor mounts?
Thanks.....
SchnorrCS is offline   Reply With Quote
Old 11-16-2011, 10:42 AM   #2
SchnorrCS
Re: Front end jacking
Oh come on guys! Nobody?
Old 11-16-2011, 10:57 AM   #3
1963c-10
1963c-10's Avatar
Thats what I do. Jack stands on the frame rails.
1963c-10 is offline   Reply With Quote
Old 11-16-2011, 11:15 AM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
I normally jack mine up under the center of the front crossmember, and place jackstands under the heavy lower inner control arm tubes. This provides very stable support directly under the greatest mass of weight.
Old 11-16-2011, 11:43 AM   #5
SchnorrCS
Even with a factory cross member?
Old 11-16-2011, 12:39 PM   #6
MOJO1963GMC
MOJO1963GMC's Avatar
I guess it just depends on where I can get that jack in SAFELY, and that it won't get in the way of anything. I usually use stands with the jack, all the weight on the stands and then the jack under tension, just for a little extra.
MOJO1963GMC is offline   Reply With Quote
Old 11-16-2011, 01:45 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
my truck sits too low to get even a low pro jack under the front crossmember, and my exhaust shrouds my frame rail....SO I have to used a block of wood on the frame rail, then jack up against the wood. That OR back up onto ramps, then jack up the front.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-16-2011, 02:48 PM   #8
ChuckW
ChuckW's Avatar
I jack using the center crossmember and put the stands under the fwd. frame... Works great and is stable
ChuckW is offline   Reply With Quote
Old 11-16-2011, 04:02 PM   #9
Dustin07
Stirrer of the Pot
used crossmember last night, but currently working on an idea in my head for a sneaky way of getting under down the road in case of airline blowout when laying frame (not yet).
Dustin07 is offline   Reply With Quote
Old 11-17-2011, 12:56 AM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
onboard air tank->extra dump and fill->pnuematic bottle jack mounted inside frame rail. = Formula 1 style onboard race jack.
Old 11-17-2011, 11:03 AM   #11
Dustin07
Stirrer of the Pot
thats actually a fantastic idea me thinks
