Old 11-15-2011, 11:29 PM   #1
crushermechanic
crushermechanic's Avatar
headlight connector ?
does anybody know the part number for the pins that go in the headlight plugs? and if so where i could find them.
thanks chris
crushermechanic is offline   Reply With Quote
Old 11-16-2011, 06:37 AM   #2
cdowns
cdowns's Avatar
Re: headlight connector ?
local autoparts store// in the "help" section i've seen pigtails with the complete connector assys for headlights
Old 11-16-2011, 08:47 AM   #3
mrein3
mrein3's Avatar
Next time you're at a junkyard pull one. All you need is a little, flat blade screwdriver to depress the tang in the metal wire connector that is inserted in the plastic connector.
On your way home stop by NAPA and purchase a handfull of part number 725147. This is the female, metal connector that is crimped on to the wire then slid into the back of the plastic connector.
Buy extra 725147s and keep them on hand. They fit in most connectors in your truck and are handy to have around if you find an issue that needs to be addressed in your wiring.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 11-16-2011, 08:58 AM   #4
MARKDTN
I would just buy the pigtail or get it at a junkyard. Headlights have a wider spade so a type 56 or normal female spade connector does not fit.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 11-16-2011, 11:16 AM   #5
barry h.
barry h.'s Avatar
Napa
barry h. is offline   Reply With Quote
